09-30-2019, 11:20 AM   #1
Pentax K-1 pixel shift processed with RAW Therapee
I have been enjoying my K-1, and recently have branched out from Manual settings only to try Pixel Shift. I've tried to understand process and have become confused. So, I will give you my workflow with RAW Therapee (RT), and maybe someone with tell me where I'm going wrong (if I'm going wrong).
1. Shoot a pixel shift RAW image with the K-1
2. Open the file in RT
3. Click on the RAW icon (it is the checker board icon)
4. Under the 'demosaicing' hit the down arrow for 'method'
5. Choose 'pixel shift'
6. Go to the 'Color' icon, click and go to the bottom and choose your color output profile
7. Finish your processing as normal, save in 16 bit TIFF
Am I doing this correctly?
John
09-30-2019, 11:36 AM - 1 Like   #2
Yes. The difference is most noticable in dark areas with high ISO. Also check the motion mask, since too much motion will null the results.
I posted a extreme example at pixls, which was very helpful to understand the use and limitations of PS.
[Play Raw] Sunset: Pentax PixelShift ISO 12800 De-noise challenge - Play Raw - discuss.pixls.us
09-30-2019, 12:19 PM   #3
Flanoman's Avatar
Thanks for this discussion John and k1n8 as I also need guidance on pixel Shift using Raw therapee .hope others can help.
09-30-2019, 01:15 PM   #4
It's best to explain from an actual photo, since under some conditions PixelShift results will have almost no differences from normal demosaicing.
09-30-2019, 01:38 PM - 1 Like   #5
You're better off selecting a pixelshift preset in the top left drop box whilst in the edit tab. This applies some other settings that are beneficial to pixel shifted files.
09-30-2019, 02:11 PM   #6
Thanks, a couple of things so far that I haven't done correctly.
---------- Post added 09-30-2019 at 02:46 PM ----------
House, sorry to bother you but I'm not good with computer English. My bundled profiles include pixel shift, and I shoot at ISO 100. So do I choose 'PS Low ISO?'
09-30-2019, 06:41 PM   #7
kiwi_jono's Avatar
While I have not done much with Pixel shift myself (I rarely shoot a scene static enough), I certainly like RawTherapee. I will also take on the advice linked from here.
Thanks for posting, John, and it would be great to see your results now!
09-30-2019, 09:44 PM   #8
kiwi_jono, like you I haven't done much pixel shift (PXS). My photo with PXS have been just trial runs. But with the adjustments that I have received above I have to say things are looking much better than my first attempts. I'll put one up in the next few days.
I will also revise my workflow if I get more advice.
09-30-2019, 10:08 PM   #9
QuoteOriginally posted by john carter Quote
Yes, use the low iso preset.
10-01-2019, 02:41 AM   #10
Your work flow looks about right. Once you find that you have settings the way you like them, save the preset and apply it to future pixel shifted images.
10-01-2019, 07:49 AM   #11
If you want to squeeze the last bit of shift out of those pixels you turn on the motion mask in the demosaic tab and adjust how much gets detected as motion. For some scenes the defaults are rather conservative.
10-01-2019, 08:35 AM   #12
Thanks everyone, I feel more confident now about what I'm doing and what I will do. I hope others that try pixel shift will use this thread, as I'm sure there are other photographers that have been confused like I was (and maybe still am).
10-01-2019, 09:01 AM   #13
I'm far from an expert on pixel shift, but would also throw out doing some comparisons with the in camera processing compared to your efforts in Raw Therapee. I'm thining it will give somewhat of a baseline/sanity check on the results your getting.
10-01-2019, 10:49 AM   #14
My revised workflow:
2. Open the file in RAW-Therapee
3. Under 'Processing Profiles' you will see 'last saved' click on this arrow
4. Now you will see "bundled profiles" click, then click (pixel shift) then click "PS ISO Low" (I used 100 ISO in camera)
5. Finish post processing as normal
7. Save in 16 bit TIFF
Here are three images from Flickr: first the entire scene, second and third are crops (second no pixel shift, third with pixel shift):
Pentax K1 Pixel shift | The large image is the scene, of the? | Flickr
The Pixel Shift crop looks a little over sharpened, I'll have to do more research. Any further suggestions?
10-01-2019, 10:56 AM - 1 Like   #15
PS iso low uses both a lot of RL sharpening and additional microcontrast sharpening. Both are under the detail tab. Try turning the microcontras on/off att 100% zoom as well as pulling the sharpening amount back a bit. It's at 100% default using PS iso low.
24x36mm, click, full-frame, icon, k-1, k-1 pixel shift, pentax, pentax k-1 pixel, pixel, shift
Raw Therapee Pixel shift work flow GUB Digital Processing, Software, and Printing 11 07-15-2019 02:17 PM
Pixel Shift processing in Raw Therapee.. saving to a tiff neal_grillot Digital Processing, Software, and Printing 15 04-16-2019 09:29 AM
Lloyd Chambers Prefers Pentax Pixel Shift To Sony's Pixel Shift Fenwoodian Pentax K-1 & K-1 II 2 07-16-2018 02:15 PM
Raw Therapee Annoying Auto Levelling Raw BruceBanner Digital Processing, Software, and Printing 8 03-25-2018 06:21 PM
RAW therapee needs Pentax RAW files. superpowerpinger Digital Processing, Software, and Printing 3 10-02-2017 08:22 AM
All times are GMT -7. The time now is 06:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
