Originally posted by fiddlefye
I guess I was thinking initially of the functionality aspect, what the experience of using K and M lenses on the K-1 is actually like. I'm pretty familiar with the look of vintage glass on FF digital in the general sense and like how it works out.
The biggest issue, for me is the lack of flash support. Unless you shoot with A series or later, you give up on through the lens metering (TTL). Since the *istD series Pentax has dropped dual flash support and shifted to only P-TTL that requires to know the native and stop down aperture values for a lens. The Pentax system , like both Nokia and canon, use a pre flash With the lens wide open, to measure the flash vs ambient ratio and then with then calculates the flash needed for the exposure settings based upon the flash GN and set iso, shutter and aperture. While this stops the issue of overexposure in some blended lighting situations, I find the preflash drains the flash batteries much faster, and disturbed wild life much more than classical ttl metering. I wish the flagship lines offered both systems.
