02-01-2020, 11:23 AM   #1
DA* 16-50 lens on Pentax K1 camera
Hi. If you use a DA* 16-50 lens (APSC) on a K1 camera, do you get the whole image or vignetting? If so is the problem across all focus lengths (mm etc)? Thanks.
02-01-2020, 11:36 AM   #2
DA* 16-50/2.8 usable at 24mm on the K-1? - PentaxForums.com
02-01-2020, 11:47 AM   #3
16-50 DA* on K1
Krazny: Thanks. I spent ages searching but didn't find this. It won't work at any scale! Regards GW
02-01-2020, 03:10 PM   #4
I’ve found it works better with the hood off... but it still vignettes like mad at most focal lengths...
I’ve also noticed that outside of the APS-C image circle it gets worse fast.
But it’s more usable for square format shots.
-Eric
02-02-2020, 12:31 AM   #5
david94903's Avatar
You might find this resource helpful.
Pentax K-1 and SMC Pentax-DA* 16-50mm F2.8 ED AL [IF] - Compatibility | PentaxForums.com
And also this one.
http://k-1-lab.com/en/smc-pentax-da-s-16-50mm-f28ed-al-if-sdm
Last edited by david94903; 02-02-2020 at 12:34 AM. Reason: added additional nformation
02-04-2020, 07:01 AM   #6
I’ve found you can TECHNICALLY use it On the K-1, but like everyone has said you get crazy vignetting. The only time I’ve used my DA* 16-50 Ion my K-1, I’ve switched it to crop mode
02-05-2020, 02:15 AM   #7
Thanks everyone. If you switch to crop mode on the K1 you only have access to 15 megapixels - 10 less than my K3-II camera. Having checked other sites it seems that the same problem will occur with all my current lenses - 10-17mm fisheye, 15mm limited, 16-50 DA*, HD 55-300 telephoto etc. The only real solution is to buy some FA lenses! With the camera costing £1700 (£900 secondhand) and an HD FA 24-70mm lens costing £1033, that might not be soon! Thanks again.
02-14-2020, 12:26 AM   #8
UncleVanya's Avatar
QuoteOriginally posted by gwoodward Quote
The primes are less restrictive. Da 35 (not macro), 40, 50, 55, 70, 200 & 300 all give good coverage (not perfect) on FF.
02-15-2020, 09:51 AM   #9
pschlute's Avatar
If you were to use the 16-50 in FF mode and then crop the picture to remove the vignetting, say to an aps-c sized picture you will also only be getting 15MP. They are both two sides of the same coin.
The answer is to use FF lenses. I agree they are not cheap. You do of course have access to many Pentax legacy lenses, some manual focus and exposure but F and FA lenses are fully automatic. I like the FA 50mm 1.4 lens on the K1. You can pick these up new still or best bet is grab a second hand one for a couple of hundred pounds.. Great IQ and very fast.
02-16-2020, 06:10 AM   #10
Thanks Pschlute. I've decided not to bother trying with my old lenses and save up for a K1 and an FA 24-70 lens, almost the same range as my APS-C 18-50 DA* lens. On current prices I need around £900 for the 2nd-hand camera and about £500 for a 2nd-hand lens. Watch this space in about 6 months time. Regards and thanks to all.
02-18-2020, 05:23 PM   #11
pschlute's Avatar
Using all my old film lenses on the K1 at the FOV they were made for is half the fun of owning a K1
04-04-2020, 06:46 AM - 1 Like   #12
Vivitar 80-210 series 1 has always been my favorite lens for my Pentax MX. And finally i can use it again with my K1 with a viewfinder that reminds me at my MX.
24x36mm, camera, da*, da* 16-50, da* 16-50 lens, full-frame, k1, lens, lens on pentax, pentax, pentax k1
For Sale - Sold: DA and HD DA Primes: DA 50 1.8, DA XS 40mm, HD DA 35mm, DA 21mm, HD DA 15mm Amarony Sold Items 8 02-20-2019 06:21 AM
For Sale - Sold: DA 12-24, DA 35 , DA 40, DA 16-45, Sigma 18-250 - Only not sold -DA 16-45 now $150 TGaa Sold Items 11 05-04-2016 04:50 PM
Shootout #2 - DA 15 Ltd / Tamron 17-50 @17 / DA* 16-50 @16 / Sigma 10-20 @16 EarlVonTapia Pentax SLR Lens Discussion 4 06-23-2013 10:17 PM
All times are GMT -7. The time now is 01:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
