Originally posted by Sandy Hancock Welcome!
Obviously the FA Limiteds (31 and 43) fit the bill perfectly, except for price. The DA 35/2.4 (dirt cheap) works quite well on full frame, and the FA 35/2.0 (very reasonably priced) works perfectly. The DA 40/2.8 Limited also works quite well.
As for telezooms, I have the new DFA 70~210/4.0 and love it, but if you're after something cheaper (but still with AF) look for a second hand F 70~210/4.0-5.6
Looking around on the feedback, I think the DA 40 2.8 would be a great lens - 40mm seems to be good for street, and the compact size would be a nice option to have. I also have great experience with pancakes from the past, so having one in the mix would be great. Thank you very much for the input!
---------- Post added 05-01-20 at 02:14 PM ----------
Originally posted by aslyfox Welcome to the forums
you will find friendly members and knowledge here
and an opinion or two ( three, four, five - - - ) on how you might choose to spend your money on equipment
this article might be of interest as a starting point:
Read more at:
Recommended Pentax Gear 2016 - Gear Guides | PentaxForums.com I will make sure to dig it through, thank you very much! It's good to get familiar with the ecosystem
Originally posted by BigMackCam Welcome to both the forums and K-mount "system"
You have some very nice lenses already. Given you're on a tight budget right now, how about the old SMC F35-70 f/3.5-4.5? It's decently sharp (pretty good even at max aperture), renders nicely, it's no bigger than many prime lenses, and a decent example should only set you back around $50 - $60 (perhaps even less if you're not too concerned about cosmetic condition). It would make a great walk-around lens for the K-1II, I think...
Just looked through the review of the 35-70, looks like a very beautifully rendering zoom! I'll keep it in mind
I'm looking primarily for a prime though, not that I remembered to mention that in the OP!
Originally posted by aslyfox Very informative, thanks!
Originally posted by pschlute Welcome. The FA 50mm 1.4 is a reasonable price second hand. I often use it as a walkabout combo on the K1 to save weight.
Ah yes, a 50/1.4 - would be nice to upgrade the 50/1.8 at some point
Originally posted by Mans Hagberg Hello and welcome! I took the step to K-1 at the New Year 2020 and find the camera just great.
For your need, I can really recommend the SMC Pentax-FA 1:2 35 mm. One sits on my K-1 most of the time. I got it in fine shape at Tradera for about 1200 Swedish krona including the original sun shade, an item worth using.
This is the elder sister of the Plastic Fantastic Pentax DA 35 mm f 2,4 AL lens. I picked one up for 400 Sw Krona. It is extremely light and works perfectly well on the K-1. Stopped down to F 11 it shows no vignetting but there is some at fuller apertures. And it does not come with a sun shade as standard.
Very cool, I've always liked the 35mm focal length, noted!
Originally posted by UncleVanya As several have said:
DA 35 f2.4 - plastic, cheap, good
DA 40 F2.8 - tiny gemlike lovely rendering
The two above are good on FF but I'm not certain of their vignetting since I'm only shooting apsc.
The FA 35 F2 either smc or hd is reasonably priced and quite good. I like my copy nearly as much as my FA 31. In tests of old the FA 35 had better edge sharpness at wide f stops that the FA 31 and while the center wasn't quite as sharp it was close. There's more to lenses than just sharpness if course but it is indicative of the high quality of the lens.
I think it's going to be a 40mm pancake for now
Originally posted by UncleVanya The DFA 100 is outside the range you specified and the macro function duplicates the 50mm macro... However it is a fantastic Jewel like lens with excellent rendering. It is a little slow to focus due to the long focus throw.
Read about the 100mm 2.8 early on, it's on the wish-list!
Originally posted by btnapa Welcome aboard. Yes for most part!!! I was told to get lost a few times because I mentioned another brand and criticized Pentax for being a sleepwalker!!!
You bought the "beast" right off the bat. You have an excellent collection of lenses to begin with. For a "cheap" tele-zoom, look at the Tamron 70-200 f2.8. I own one and I love it. I paid full price. You can get one for a good discount in the used market. If you have the funds go for the Pentax version.
For this one you have to get a piggy bank and save up. You have to have the Three Amigos (FA 31, 43 and 77). They were made for the K1. I own all three and the images they produce in conjunction with the K1 are sublime. I call the combo my medium format replacement. You have seen what K1 can do already.
BTW, I also own some Fuji cameras and lenses, mostly for video work. For the ultimate still image quality K1 is the undisputed king.
Sounds good! Yes the limited lenses are definitely on the want-to-buy-when-winning-the-lottery-list - some of them are quite affordable, whilst others seem to break the bank. They look like they render amazing.
