Originally posted by Serkevan Why would anyone consider a third e-dial a compromise? It adds functionality at very little cost.
Also, CF cards fail as much as SDs, they work on the same principle. Anecdotal "but my card died" experience is not relevant.
*rolleyes* ... Gotta love the confusion...
Again:
Its not about the e-dials..
Because they have been there since K-7
And sit exactly where you need them.
One on the back where your thumb is..
And one on the front of the grip where the pointing finger finds it immediately.
And yes you are right... With those 2 and the actual mode dial.
That was also there on the K-7 already and a lot of other traditional models,
you dont have to lift your Eye from the viewfinder.
100% correct congrats.
Especially if you read the manual
Changing ISO via holding the iso button and turning the rear e-dial is easy ...
Not holding ISO-Button and turning it will set the aperture...
Whilst most of the time you would change the time with the front e-dial.
You can do a lot of configurations.
which already open an overwhelming amount of possibilities...
Right so far. But...could you tell a grownup,
what kind of advantage do I get from additional wheels that offer redundant functionality thats already there in a lot of ways??
What else do they add to the design of our cams, than
3-5mm protruding moving weakpoints that may make me think im holding a fuji.. What?
Sry I dont get the point even if you repeat your mantras again and again.
Its the same with those new japanese designs that add weird looking shiny application element to kind modern touchy grip "beleathering".
I once chose a K-5IIs over a D600 . And i did not that because the K-5IIs looked fancier and had a lot of fancy input elements...
And no... CF Cards do not fail as often as SDs because they actually dont .
And CFExpress will also be nearly 100% unlikely too fail ...easy as that.
And that has nothing to do with a one-day experience.
A lot of expertise tells me that.
Physics tell you that. Because there is much more space ...
The small room SDs offer causes a lot of heat.
Get your bacon ready gentlemen...
There is also no and I said NO space left for fallback
""banks"" and SD's are very unlikely to offer SLC-grade cells because of the space.
Also not the slightest chance for any kind of good ECC.
So there is not even the slightest chance you can say an SD can be on the same level as an CFExpress or XQD. Read it slowly: NOT A CHANCE.
There is a good reason broadcasting cameras dont use SD... but they do/did use CF,XQD, CFExpress.
Sry for you guys but if you want
Real "PRO GEAR" you will need PRO MEMORY MEDIA
And if 20 Pro-SD guys together hop in a circle and tell each other to have a good time... Then yeah ...
Youll have a good time...
But you will not change fact.
You will not change physics.
Sry I have to say so.
But what this brand needs is honesty from their customers. Otherwise they wont change anything.
We will never profit fromthis "nah everythings a okay"..
Or do you really believe that?
