Originally posted by photoptimist The FOVs of the K1 and LX are virtually the same* but the photosensitive surfaces are not. Film and silicon sensors have very different optical properties that affect performance in the corners.
For film, the matte surface of emulsion can readily absorb light coming from all angles.
For digital, the microlens-studded surface of a silicon sensor cannot readily absorb light coming from all angles. The microlenses int he corners are optimized for certain angles that assume the exit pupil of the lens is a certain distance from the film plane. Older ultra-wide angle lenses may have exit pupil distances that are too close to the film plane and that cause vignetting.
*The exception to this occurs when shake reduction, composition adjustment, or astrotracer are used. These features shift the sensor up to 1.5mm in both directions which puts one or two of the sensor corners further into the extremities of the lens's image circle.
P.S. This fact about silicon sensors is one of the reasons that the short mount distance of MILC cameras doesn't really enable lenses as small as proponents of MILC might think. MILC still require retrofocus designs (or heavy vignette correction) with wider lenses.
This is interesting to me. Although I've yet to be fitted for my dunce cap, intuitively what you wrote makes sense. However, I have not been able to find similar information concerning the large diameter/short flange distance of the latest MILC offerings (Nikon for instance, but they are not alone). I was interested in the Z series cameras.
Does this help explain the 645Z appeal/performance with 'old' tech? Because a MF mirrorless (Fuji, H-blad) could be in a similar boat as the new FF ILCs. Of course, I just assumed (due to lack of other sources indicating this) that it is a technicality that doesn't affect the image as much as one might construe.
