Originally posted by Bob 256 Longer lenses have a narrower cone of light whereas short FL lenses have a wide cone and edge rays hit the sensor at a considerably sharper angle that center rays so vignetting will be more pronounced.
Three words: Exit pupil location
This can be visually estimated by direct examination from the rear of the lens and for some short teles is sometimes closer to the sensor than the typical ultra wide. I just checked my Samyang 14/2.8* and it appears to be about 10mm beyond the lens flange towards the front of the lens. 10 + 45.46 = 55.46mm or about the same as for my ST 55/1.8. My Tamron 24mm is about 5mm forward of the lens flange. Shallow angle of incidence is likely to cause a problem due to optical vignette (huge issue with even moderate wide angles on view cameras) alone, even without consideration of sensor well depth/orientation.
* Recent purchase 3rd generation for that lens.
