Originally posted by ismaelg Start with TAv mode, 1/100s, f2.8 and adjust accordingly on the fly.
Important: Weddings are tricky for many factors including some things that happen very fast and can not be repeated. So be ready to draw and shoot fast.
Thanks
Thanks so much for the reply. I am now practising Tav starting at these settings. Much appreciated.
---------- Post added 07-26-21 at 04:11 PM ----------
Originally posted by Bob 256 Which option? I believe it has Sv, Tv, Av, and TAv priority options, as well as program mode which can be switched to shutter or aperture priority with the flip of a front or rear finger dial.
I need to use the program mode, that sounds ideal. Why have I not investigated this yet? ����
---------- Post added 07-26-21 at 04:13 PM ----------
Originally posted by MrB1 Assuming the K-1II behaves like other Pentax DSLRs (I have a KP) and that you want to use Av Mode, then set the ISO to Auto - lower limit 100 and upper limit as high as you are prepared to go to maintain quality (perhaps 3200 on K-1?). The camera will then not allow the shutter speed to fall below the old rule of thumb of 1/focal length, unless the light is so low that the chosen upper ISO limit is not high enough.
Philip
thank you so much, I'll try this option too.
---------- Post added 07-26-21 at 04:15 PM ----------
Originally posted by peggers Maybe it is possible to set up a USER preset. In it you could use a shutter priority mode and set the shutter speed to your desired speed, maybe run with auto iso too? In it you could also specify spot metering or whatever you desire
Great idea, thank you so much. All of these replies remind me how much I still have to learn about DSLR photography let alone my k1ii which I've had around six months!
---------- Post added 07-26-21 at 04:20 PM ----------
Originally posted by beholder3 Technically you will get the best possible results with M at fixed ISO 100 and your preferred Aperture and minimum shutter speeds (= longest tolerable exposure time like 1/125 sec or so) dialed in.
That will yield lots of underexposed images, but since you can fix these raws in post without any significant penalty versus choosing higher ISO initially due to the K-1's ISOless sensor. This yields the biggest possible max dynamic range for all images (because ISO 100).
Caveat:
This will not protect against overexposures, so if you use a very fast lens and shoot outdoors then probably you will need to manually choose even shorter shutter times.
No different from using TAv, though.
If you feel uncomfortable with shooting a wedding already this probably is an approach out of your comfort zone.
The setting max exposure time is only available in cameras from KP onwards I think.
Yes, this sounds reasonable. I tried this method shooting a school play a few days ago and it worked pretty good. Thank you!
---------- Post added 07-26-21 at 04:30 PM ----------
Thanks again everyone.
I am used to shooting mainly in manual but I think these next few weeks will be an opportunity to see what my k1ii can do, the possibilities to set it up the way *I* want it; I've not even touched the P mode nor do I have any user modes set up. It's about time I do.
I am comfortable shooting events but weddings are a bit scarier for me. I also suffer from Imposter Syndrome even though the jobs I get are mainly from people who like my style and my work. I will just get over this insecurity and remember the last weddings I shot. I'll have my trusty k1ii and K3ii with me which already fills me with confidence.
cheers all
