Originally posted by Wheatridger Hey, Turbo Bird, which of those lenses I sent to you is pictured here? This one looks partially dismantled.
Both of them are ones I got from you. I cannibalized the one that's disassembled and put the front element in the one on the left, after cleaning out the autofocus gear drive. I didn't really know how to get the front element out and didn't want to disassemble everything from the back, so just gave it a twist and it came out, but that broke the tabs off that lock it into the focus mechanism. I ended up having to build up new tabs with JB weld and filing them to shape, and have it working for now. I don't know how durable it will be, but at least now I know how to fix it again if need be. I also cut and spliced the stretched rubber on the zoom ring, so it won't disappear like the other one had. I'll hopefully be able to give it a try this week sometime to make sure it focuses properly and all that. The filter threads are still messed up though, so I stuck a cheap eBay aluminum hood on it, which doesn't look to vignette at all, even at 24mm. I'll probably leave the hood on and not worry about using filters with this lens, it's kind of a pain to get anything to thread on straight. I was pretty bummed out when I realized what I'd done by twisting the front element, but I'm much more optimistic now.
Kristian
