Originally posted by MarkJerling Thanks! Yes, I love doing that too. Mind you, I like to know the history of all the unusual things I collect.
Just you writing about it and I can smell Beetle interior!
Ouch! Reminds me of my one friend who had very nearly completed a body off chassis rebuild of a '58 Cadillac convertible. Stunning car. One of the very last things that needed doing was fitment of a new exhaust system. So, car was up on the lift, new exhaust system fitted and the last job to do was to check for leaks. So, mechanic reached into the car through the open drivers door to start it and in the process he bumped the gear shift into reverse. The Caddie lurched backwards off the hoist and tore the door off in the process, also making a big mess of the rear end as well as the front fender that connected the hoist pillar due to the sideways jolt of the door being ripped off.
Which reminds me of another mate who could never say no to a freebie. So, he's tooling down the highway in the '57 Fairlane 500 when he looks in the rear view mirror and sees a whole heap of smoke pouring out of the back of the car. He pulls over and opens the trunk. Inside, there's a raging inferno and he realises too late that the "free" pool chlorine container he had earlier picked up from a mate had fallen over - and so had the bottle of brake fluid he kept in there because the car had a weepy master cylinder. By the time he managed to toss enough sand from the side of the road on the mess the car had burnt all the way to the rear parcel shelf. The petrol tank (under the trunk) did not erupt, which would have made things rather more spectacular.
Great stories....makes me cringe and also be grateful that it didn't happen to me.
So far, I've been fortunate, no cars falling off lifts.
Although I did consider buying a small lift for my motorcycles, in order to bring them up height wise, to work on them. I'm sure they're good, but I dunno...in the back of my mind I can just see my SR 500 or Matchless Scrambler toppling over, onto the concrete garage floor.
Back in the late '60's when I was driving my first car, the '61 V-Dub, I took it into a garage for an oil change. I waited for the car to be done, paid the bill and drove off. Not too far away from the garage, I was driving quickly through my favourite series of twisty road and the red oil light came on. This happened sometimes when I would push the VW hard in the corners...a bit of oil movement to the side of the oil pan due to the great G forces
, generated no doubt by my old VW's 5.60-15 belted tires.
This time I thought somethings wrong, so I pulled over to the side of the road, flipped the hood and saw part of the inside of the hood was covered in oil. I quickly saw the problem, the guy doing the oil change had forgotten to put the oil filler tube, oil cap back on. I stuffed a shop rag into the hole to stop the blow by .checked the oil and saw the level was down by about a quarter on the dipstick. Drove the couple of miles slowly to the garage and the guy was red faced with cap* in hand. He apologized profusely , topped up the oil, cleaned the inside hood, put the oil cap back on.
What did I learn? A couple things.
Getting your oil changed at a small garage with one guy on duty who also responsible for filling up customer gas tanks, cleaning their windshields, handling the cash register and other duties as assigned...can be a dicey thing. Very distracting for the worker, which can lead to moments for the busy guy of...geez,,,did I tighten the oil pan plug, did I check how much oil I out in....etc.
So either change the oil personally or go to a large garage that has people who do only one thing...change oil.
Since then , immediately after I get my oil changed, I flip the hood, and check that the oil cap is on securely, check the oil dipstick level, check that the oil filter is secure, look under the engine for any leaks.
Experience has taught me to do this and I agree with Will Rogers, American humourist who I think summed up these matters best, IMO.
"Good judgment comes from experience, and a lot of that comes from bad judgment.”
* oil
