Originally posted by lesmore49 Your wife is a serious weaver ! Quite a machine. Does she make quite a few blankets ?
She has in the past, but this may be her last blanket. Moving the treadles is pretty serious stuff and at 65 it takes a lot out of her. The loom has 8 harnesses. More harnesses means more complex patterns can be woven. When you push a treadle to lift whatever harnesses need to be lifted for that throw of the thread you are not only working against the weight of the harnesses lifted, but also against the tension on the warp. To create the shed for the shuttle to race through is like pulling the stings back on hundreds of bows on a wide warp like a blanket. The treadles provide the leverage necessary to do this. This blanket will be some 90 inches (228 cm) long and maybe 80 (203 cm) inches wide.
The loom in the photograph is capable of weaving cloth up to 48 inches (121 cm) wide an she may be working against the tension of several hundred individual warp threads. Also the long throw of the shuttle on a wide warp is getting pretty stressful on her shoulders. It is a more physically demanding craft than one would initially think. The working of the beater is more touch and finesse than brute strength. If it is not kept even then it will have a big effect on the fabric.
She has made several coverlets and blankets over her lifetime. Lots of smaller items too. Recently she wove some fabric and made a jacket for herself from it.
She also spins fiber and sews. Her hobbies really need there own building. The room the loom is in is officially a family room on the architectural drawings. Instead it has the loom and a Husqvarna embroidery sewing machine.
