Originally posted by Racer X 69 There is a blade inside this crate. Somewhere in Texas.
Cool. I've never seen one in a crate before.
Originally posted by Racer X 69 This video shows the process. Keep in mind the colossal size of these things. Over 125 feet long. I read an article about the process, and VOC (volatile organic compounds) emissions are a concern, given the large quantities of chemicals used. Manufacturers are taking measures to catch the VOC emissions during the vacuum Infusion process, thereby resulting impact on the environment.
Very cunning. The largest ones have a rotor diameter of 220m so 721 feet, give or take. That makes each blade at least 355 feet long!
We don't have anything that size here. But the ones we do have still require amazingly large concrete footings. Each footing for the ones we have here is 375 cubic metres of 30MPa concrete and 28 tonnes of reinforcing steel. Now, take into account that each concrete truck transports 6 cubic metres of readymix and you'll see that, for each footing, that means 63 concrete truck loads! At four trucks an hour, you're still looking at a 16 hour continuous pour.
