Originally posted by MarkJerling Sorry, grandson. Still, Sync 1 was the only one without navigation, so must have been Sync 1, which was Windows based. Sync 1 was a bit of a dog.
Decided no navigation was better than the Android Auto software built into the 2020 Subarus. Really it gets all its data from the connected phone and just puts it on the car screen. With one little quirk... When the phone loses cellular connection by entering for example a deep but narrow valley, GPS continues to work and uses the cached map. However, if connected to the car's screen when the cellular signal drops, the map tends to freeze and when cellular returns shortly later, the map starts to guess where you are - amusing when you are out in the country and going to be on the same road for some time. Not funny at all when in a city and need to make a number of turns in short sequence. The only fix is to pull over, cancel navigation on both phone and car screen, and start from scratch entering your destination. I purchased a stand alone GPS for the top of the dashboard.
