Originally posted by Parallax There are relatively few basic types:
Open (commonly called "compound"). - The bone either protrudes through the skin or there is an open wound in the proximity of the fracture.
Transverse - The break is at or very near 90 degrees to the bone.
Oblique - The fracture is at an angle.
Spiral- Self explanatory
Comminuted - Multiple fragments. The bone is essentially crushed.
Greenstick - Only occurs in young children when the bones are soft enough to break only part way through.
Do any of those names ring a bell?
Of course those all refer to the actual type of fracture of each individual bone. There are names for site specific fractures such as Lafort type I II or III fracture of the face, flail chest (two or more adjacent rib fractures with two or more fractures per rib), colles fracture (wrist. both radius and ulna), etc. You said she had a tib/fib fracture so I wonder if there isn't a specific name for that as there is for the equivalent wrist fracture.
He wrote "closed fracture of right ankle", then "closed fracture of the malleolus of right ankle" on the release notes.
Today I read the full chart notes, and in addition to the above, there were comments when the second set of x-rays were ordered, and again later when the ultrasound was ordered, regarding suspected fracture of the distal of the tibia and fibula.
The picture of the x-ray with the plates and screws is what I found searching the innerwebs.
Having seen what looked like a wedge of bone poking up under the skin right after the fall makes me think at least one fracture was nearly vertical, rather than transverse, and at the end of the bone.
Mrs. Racer told me the doctor shot her with "hundreds" of shots from mid lower leg down to, and all over her foot and ankle. Then the nurse slipped a tubular gauze, and after the shots began to work (must have been a local anaesthetic), the doctor came back, and with an assistant, set the break, took a few more pictures, then they applied a splint, and sent her on her merry way.
