Originally posted by novsky Hi Awaldram, so u've got some ? No latency in HSS ? Do u think it will be possible to link 4 Flashes (into a big softbox) with an optical cable ?
Now that we know that K3 can't control HSS with internal flash (cf manual), i will lost 1HSS flash to control the 4
Latency is not an issue, also the same modules work for Canon,Nikon,Sony,Olympus or Pentax a truly multli manufacturer product.
Not sure of your question but I 'll try and answer what I think it is.
The modules only replicate functionality already present in the local solution.
i.e you need an HSS capable flash on the body for the TX to Transmit HSS data to the RX
So for your 4 (hss) flashes into soft box you need.
1 5x HSS capable flashes
2 1 X P-ttl TX
3 2 X P-ttl RX
4 2 X additional IR cables ($10 inc splitter)
Other functionality mentioned in these threads and how to achieve using P-ttl
1 Contrast control - on camera wireless can do 1/3 -2/3 ratio to external
2 ratio control - set individual ratios on each flash
3 group control - set two flashes to same setting other to different
4 man and p-ttl mixed (wireless) - set manual to requirement P-ttl will compensate to compensation levels you've set. (this will work off studio strobes)
Remote setting from camera - that for lazy niikonites climb that ladder and do it on the flash
