Show Printable Version 6 Likes Search this Thread
01-15-2015, 01:52 AM   #76
cbope's Avatar
It runs in a browser, so the phone OS should not matter, in theory. I also use WP and would be interested in compatibility with mobile IE.
01-15-2015, 02:07 AM   #77
Or Spartan
But I'm not sure its worth it to shell out so much more money for a Flucard with remote capabilities. Anyway, thanks all for the infos!
01-15-2015, 02:51 AM   #78
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by dicks Quote
$50 is a lot in photography????
01-15-2015, 03:11 AM   #79
I think you misinterpreted. $50 for a Flucard with 32GB is OK. Paying significantly more for the original Pentax card with added remote control function is imho not.
01-15-2015, 04:30 AM   #80
clackers's Avatar
But isn't the original card (with remote control) about $50 more, albeit with half the capacity?
01-15-2015, 04:40 AM   #81
cbope's Avatar
Last time I checked, the Pentax 16GB Flu card was $99.
01-15-2015, 04:55 AM   #82
They are two very different products. One is for uploading photos the other is for camera control. Of you want Wi-Fi upload, buy the standard flucard or other similar ones, eyefi for example. If you want camera control, you get the Pentax flu. They don't do the same things.
01-15-2015, 09:22 AM   #83
gebco's Avatar
Thanks, I have Windows Phone so the remote control is of no interest
I have a new BlackBerry and the remote control works in my browser, even though it isn't officially reported as doing so.
07-02-2016, 11:53 AM   #84
Eyewanders's Avatar
QuoteOriginally posted by gebco Quote
Resurrecting this thread because I've become interested in this functionality. I'm by-and-large only interested in uploading to my phone, which also happens to be a Blackberry (Passport SE). Which BB model are you running this on and can you describe the experience just a little. Tempted to grab one but $100 (price does not seem to have changed at all) is a bit of scratch especially if it isn't much fun to use. I could see myself using remote control but it's largely not needed as I have a remote for the camera, I'd just like to review/quick-edit on my phone from time to time. Thanks!
07-02-2016, 05:40 PM   #85
I picked up a 2nd hand K3 last week and the eye-fi card I was using in my K50 seems to work really well in the K3, much more reliable for some reason. I've only tested on iOS. It's only a 8gb model but works really well in slot2 for jpegs with the raw's going to the card in slot1.
07-04-2016, 07:51 AM - 1 Like   #86
gebco's Avatar
QuoteOriginally posted by chickentender Quote
I have a Z30 which I think has a bit less processing power than your Passport. I find that uploading the pics from the card to the phone works but slowly. Essentially it is uploading a full size jpeg each time. If you are doing several pics it can take a while. But I do like it for the odd time I want to post pics to FB, Twitter, etc.
I haven't used the function in a while. I will do a timed test in a couple of days and let you know.
Just a note: I cannot get my computer to read the card properly. When I put it in the card reader, the card beeps as if looking for a wifi connection then stops, and the computer cannot access. The only way of accessing is by plugging the camera in.
07-06-2016, 02:33 PM   #87
gebco's Avatar
I just put my Flu Card back into my K3 and connected to my Z30. It was actually a lot faster than I remembered. The thumbnails displayed fairly quickly, and loading a 14 mb jpeg to my phone took a few seconds. Only drawback is that you cannot just hold a thumbnail, select more and then copy, as it will only copy the thumbnail, not the full size pic. You need to tap on each thumbnail one at a time, and save each pic one at a time.
card, dslr, k-3, k3, pentax k-3, sd, wifi
k-30 & EyeFi WiFi SD 16GB Pro X2 tsvetan Pentax K-30 & K-50 15 06-15-2013 04:13 PM
Transcend wifi card Rob22315 Pentax K-01 35 04-14-2013 02:30 AM
Any WIFI solution for K5II?? Shanti Pentax K-5 & K-5 II 8 03-29-2013 08:51 PM
Transcend SDHC WIFI Class 10 Cards David Pentax Camera and Field Accessories 9 01-23-2013 03:42 PM
All times are GMT -7. The time now is 04:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
