Originally posted by derekkite
Does not extended af areas also mean that any point in the area could be the focus point?
That basically means you have the main (selected) point, and surrounding backup points that help to track the subject.
Originally posted by StigVidar
I have not measured it, but it feel more or less like a second before K-5 IIs gives up when focus is lost and try to focusing on something else when expanded area AF is enabled.
Yes, I've just checked it - there is much longer delay if you're moving the camera from one subject to the other in expanded area mode, so there is some kind of "hold" feature built into that mode, but it is not an "essence" of it and with the K-3 you have two independent settings.
