A few more impressions of this camera. I have the af set up as follows:
AF.C
C3 menus:
15 AF.S focus priority
16 AF.C first frame focus priority
17 Action AF.C focus priority
18 Hold AF Status Off.
For focus area,
Expanded AF (S). with center point selected.
What I've noticed so far is that if the subject is large enough to fill the center focus point, it will follow it reasonably well into the other points. If it is smaller, ie. a bird far away, it takes a bit of work to get it to focus. You have to center it on the subject, and press half shutter. It will lose it sometimes, so release, line up, and half shutter to re acquire. It takes practice to focus and hold a subject in focus as it moves about; the camera helps but practice allows you to help it out.
For subjects close in, I ran into trouble when I let it get outside the 9 point array. I'm thinking I will try the 27 point to see how it works. For example there were curious gulls who would fly in and hover over top of me. The body and lens were on a monopod, so it was difficult to track accurately. I got quite a few shots in focus, but some not when the subject went out of the array.
I like the expanded area. The initial focus is in the middle where you want it, or whichever point you want initially. So when you want spot, it works like that, but with a bit of slop. I've noticed that it is easy to inadvertently press the bottom right button that selects the focus point, and the indications are not going to catch your attention unless the info screen with that information is selected. My next tweaking is setting up User modes so that it can be reset easily.
Some shots. The detail is amazing. The first is uncropped, the second cropped.
These little guys are fun to shoot. This is iso 3200, and cropped. Denoise in post processing.
