Originally posted by MJSfoto1956 probably unrelated, but having to do with the popup flash nonetheless:
I notice that when the camera is in auto bracket mode (i.e. +1, 0. -1 stops) and when the popup flash is engaged, the bracketing affects the FLASH power not the underlying exposure! (i.e. the exposures are all the same, but the flash varies). Further, it appears to me that in "slow" mode, the behavior is very different than what I am used to with my Nikon D800's "slow" mode: what I expect is that the camera attempts to balance out the exposure to sit somewhere in-between full-on flash and non-flash (i.e. ambient light) exposure. This is not what I am seeing with the K-3, which is tending to overexpose the scene by ADDING the flash to the ambient light. Is there anyway to adjust this? Or is this just a Pentax thing? (if so, I can state that I finally found something I don't like about my new K-3)
Michael
Interesting observation I thought so I sat down and made some tests. First I always have a -1 EV or more for the flash power. I feel it always gives to much flash. The K-5 I always had -2 but the K-3 is closer so -1 is what I use for fill.
That the flash changes power when bracketing with flash feels somewhat logikal, I would expect it to do that. Maybe it is because I have only used Pentax as digital SLR. Have borrowed my friends D800 from time to time but never used flash with it.
I have tested the slow sync and can't really see that it becomes over exposed. It depends i guess on if you have a dark background far away and a dark subject close that needs flash to be seen or if you test it in the kitchen. First scenario is good, second feels like it is adding to the exposure if the flash is not dialed down. I have never used it in scenario 2 before now.
If you take the same "slow sync picture" with both the K-3 and the D800 how much more flash does the K-3 give compared?
EDIT: I have made some extra tests in my much longer livingroom and out on the balcony and I find it to do what I expect it to do, light up the background with a long exposure and the foreground with the flash. Is there any other scenario I am not thinking about?
I find that the inside of my appartment is to small due to the amount of flash that can be produced, I can make my livingroom very bright with this little flash on ISO100...
Reason: Adding
