Originally posted by crewl1 Toshiba 16GB Exceria Type 2 SD-H16-GR7WA6 SDHC Card r95MB/s w60MB/s Class 10 (CRA-ET2-RT) Retail
The R/W speed of the Toshiba is 95/60 MB/s
The Sandisk Extreme Pro is 95/90 MB/s
The Exceria price is good, but it's the 50% faster writing time of the Extreme Pro that should make a significant difference when the buffer fills. With sports, I currently spend a lot of time waiting for the K-5's buffer to clear. It's very easy to do this when you're taking a lot of bursts in a short period of time e.g. hurdles or a sustained goal attack in soccer. When I get the K-3, with its bigger images and updated SD R/W hardware, I want to give the buffer the best chance.
I'm usually an exclusive raw shooter, but I may even consider shooting JPEG at 14MP, as I don't think my two main zooms (DA* 60-250/F4 & Sigma 70-200/F2.8) will out-resolve this image resolution. (When I get the K-3 I'll perform some tests shots of printed text at a distance to confirm this suspicion.) Buffer depth and speed would then not be an issue.
But if you shoot lots of raw or raw+JPEG bursts with the K-3, then SD write speed will be highly significant.
Dan.
