11-14-2013, 06:57 PM   #1
Otis Memorial Pentaxian
K3 Moon versus K5 iis moon
I took a lot of pictures tonight...more with the K3 using the Sigma 500mm but a few with the k5iis...all were shot at 160 shutter and f13...I have been dealing with focus issues with the K3 and the 500 so not sure if what I experienced tonight is because of that...you can see the 2...shot on the tripod and cropped the same ...look at them first ...at the bottom I will tell you which is which
IMGC7110
by pearsaab, on Flickr
IMGC7110 | Flickr - Photo Sharing!
IMGD1112
IMGD1112 | Flickr - Photo Sharing!
the first is
k5 iis
next k3
11-14-2013, 07:15 PM   #2
Ex Finn.'s Avatar
QuoteOriginally posted by pearsaab Quote
IMGC7110
IMGD1112
the first is
k5 iis
next k3
Not a good way to judge sharpness or focus. Atmospherics play way too much into it.
IMO both images look very good from a "non telescope".
11-14-2013, 07:26 PM   #3
interesting...so even though taken at about the same time it can change it slightly...ok I feel better
11-14-2013, 07:45 PM   #4
panoguy's Avatar
#2 definitely has that "noisy K-3" look to it! (oh snap, did I write that out loud?)
11-14-2013, 07:49 PM   #5
calsan's Avatar
OK, well I reckon I can get similar detail with my K-7 and 55-300 at f6.3 and 1/320 or 1/250. Try a faster shutter speed and wider aperture - I think your setup should be able to totally trounce mine! I have found ISO 200 to get the best results with my setup also.
As mentioned - atmosphere makes the most difference. It's best when the moon is as close to overhead as possible and later at night so heat from the ground is less.
11-14-2013, 07:51 PM   #6
Ex Finn.'s Avatar
Absolutely. Not saying that the K3 might not have a problem but I normally shoot several dozen images of the moon and pick the best one from that session.
11-14-2013, 08:44 PM   #7
Eric Auer's Avatar
Both look pretty good.
I honestly had a hard time telling the difference.
11-14-2013, 09:05 PM   #8
k5astro's Avatar
I had a really hard time telling the difference but maybe after 10-20 comparisons I would say the K3 looks like a bit better resolution, as it should. But the difference would be more evident if you cropped it or printed a poster size print.
11-14-2013, 10:43 PM - 2 Likes   #9
Why use f13? You do not need much depth of field at 240,000 miles, and your lens is likely sharpest near f8.
11-14-2013, 11:58 PM   #10
skid2964's Avatar
Which Sigma 500mm?
11-15-2013, 01:21 AM   #11
hi pearsaab, nice images and congrats on the k-3,
give it another try using wider aperture... f/8 - f/9 should be better
remember that difraction kicks in earlier with the k-3... one of the caveats of having 24mp on an aps-c sensor...
11-15-2013, 01:42 AM   #12
Forget about f/13. f/5.6 to f/8 for a large object should be enough. For stars however the larger the aperture the better.
11-15-2013, 03:28 AM   #13
aaalegre's Avatar
Are you using the aa filters in these k3 photos ??
11-15-2013, 03:49 AM   #14
Sandy Hancock's Avatar
The top image looks noisier, but sharper. I would guess that is the K-3, but there's really very little between them.
With moon shots it is very difficult to make comparisons, because precise focus is so critical.
11-15-2013, 05:09 AM   #15
With a K5 and a 500mm 1/160second is fast enough, no need to go faster. I suggest base iso if the lens sharpness allows a larger aperture. Shooting at ISO 80-100 makes a huge difference when hunting for details at 100% crop.
dslr, flickr, k-3, k3, k5, moon, pentax k-3, photo
February Moon (feel free to post your moon shots) GLThorne Post Your Photos! 11 05-02-2016 12:00 PM
K3 auto WB on the K5 IIs... Santoku Pentax K-5 & K-5 II 3 11-13-2013 07:05 AM
Moon-K5 vs K10 Boker Pentax DSLR Discussion 10 12-01-2012 12:18 PM
Nature Moon shots (yop, one more thread on the moon) Martin_Qc Post Your Photos! 3 05-25-2010 10:01 PM
Nature Moon versus man Naturenut Post Your Photos! 5 03-27-2010 12:25 PM
All times are GMT -7. The time now is 08:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
