Originally posted by awaldram Jello effect is caused by cmos inability to shut off instantaneously hence you can see the 'wave' shut off as moved position during hence jello it has nothing at all to do with SR be it mechanical or electronic.
SR done in the video processing might not be the cause of the Jello-effect; the rolling shutter is. But electronic video processing does make it much worse. It exaggerates any jello effect that is present. That is why all K-5 spinoffs, with their electronic SR, show the Jello Effect so badly and the old K-5 itself doesn't. (Unless you pan like a madman on steroids.)
Originally posted by awaldram The reason they did it is pretty obvious think audio recording, and if that doesn't give you the answer stick a screw drive lens on the camera and record video whilst using on demand AF you'll get the message loud and clear
That screwdrive lens is going to make that sound with or without mechanical SR.
