I looked to other sources and here is something I found: Copied from: Ibarionex Perello. “Canon 5D Mark III: From Snapshots to Great Shots (Dylan Evers' Library). My comments in
RED
Customizing AF Function
You can further customize the camera to suit your unique shooting needs when using AI Servo AF. Customizing the autofocus function determines whether confirmation of focus, releasing the shutter, or a balance of the two will be the priority.
For example, some photographers who shoot football may prefer to weight the priority to release to ensure that they get a shot, even if it isn’t tack sharp, because it may be an important moment in game play. They don’t want to lose an important moment waiting for the camera to nail the focus. This may result in some images being slightly out of focus, but it may make the difference between getting and not getting the all-important shot.
By default, the camera sets an equal weight between focus confirmation and the release. However, you have the ability to bias the performance either way for the first and subsequent images when shooting continuously.
My reading of this is that if you want to put the emphasis on getting a shot over getting a shot in focus the the settings on the K-3 should be C3 #16 set to 1(DEFAULT) and C3 #17 set to 3. Likewise if you want the emphasis to be on getting the sharpest picture possible then the settings on the K-3 should be C3 #16 set to 3 and C3 #17 set to 1 (DEFAULT) These settings are new to me but if this is correct then Pentax should make the DEFAULT options consistent so they compliment each other. In other words the default setting should be the same with either the emphasis on getting a shot versus emphasis on getting good shots. I still have no idea what AUTO is for the settings.
AI Servo 1st Image Priority
TO ME THIS IS C3 #16 1st Frame Action in AF.C
This setting controls how the camera will perform for the first image captured during a continuous burst when shooting in AI Servo AF:
1. Press the Menu button and turn the Main Dial to access the AF2: AI Servo menu screen. Rotate the Quick Control Dial to select AI Servo 1st image priority. Press the Setting button.
- Rotate the Quick Control Dial counterclockwise to select Release to make taking the picture the priority. Rotate the Quick Control Dial clockwise to make focusing the priority.
AI Servo 2nd Image Priority
TO ME THIS IS C3 #17 Action in AF.C Continuous
This setting controls how the camera will perform with subsequent images made during a continuous burst when shooting in AI Servo AF:
1. Press the Menu button and turn the Main Dial to access the AF2: AI Servo menu screen. Rotate the Quick Control Dial to select AI Servo 2nd image priority. Press the Setting button.
2. Rotate the Quick Control Dial counterclockwise to select Release to make taking the picture the priority. Rotate the Quick Control Dial clockwise to make focusing the priority.
