Hey guys.
just wanted to point out a few issues i have encountered from my last post.
1. movies will record only on card 1. i couldn't made it go on card 2. i even took out card 1 ( as it automatically moves to card 2 when no card 1 is in the camera) .. it said that no card 1 inserted (photos worked just fine
2. the remaining photo numbering system is completely of. i mean with both cards empty ( i use 2 x 16gb lexar professional 600x) it says that i have remaining 300 shots ( all raw .dng). today the card 1 was full after around 500 shots and 200mb of video. ( which is correct. 16gb / 30mb = 533 photos). also the last photo on the card 1 was just 1mb, almost black and it had _cr in the name.( so the camera didn't calculate that there is no more space for a raw image and auto go to card 2)
3. coming back to my previous problem with the full depleted battery . apparently if you use the camera as a photo device , it will never deplete the battery completely (it will close before the battery reaches 0%). but if you connect it via usb cable to copy your photos into the computer it will drain the battery dry. hence, when put in the charger , the green light will blink for like 15 min . don't know if this issue can damage the battery but it can
