Originally posted by robgo2 The above image is an example of exceedingly poor noise reduction, which is why the red cloth shows so much detail. It's easy to accomplish this, if you choose to leave the noise largely untouched, in which case the choice of software is immaterial. I have yet to see anyone post a clean example with good retention of detail. Perhaps DxO 9's Prime NR can do the trick, but it does not yet support the K-3. I might give it a try on a K-5 sample from IR.
Rob
Below are 100% crops of IR's ISO 6400 raw samples from the K-5II. The first was rendered with Photo Ninja/Noise Ninja 4 and the second with DxO 9/Prime NR. In both cases, the programs' default settings were used except for noise reduction, in which case I sought to achieve a balance between noise removal and detail retention. Unfortunately, the web jpegs do not do justice to what I see on my monitor. My take is that the DxO file is cleaner, but blotchier, and shows less detail, especially in the red cloth. The Photo Ninja file has a fine, even grain pattern and more detail. It is also brighter, which is a function of PN's superior default settings. In any event, it should be pointed out that the K-5II has significantly less noise than the K-3, and thus requires less aggressive NR. Also, I think this removes any doubt about Pentax DSLRs generally being unable to render detail in bright red subjects. The results are actually pretty decent for ISO 6400. I will continue to work on the K-3 sample and hope for something better than what I have gotten previously.
Again: Top--Photo Ninja/Noise Ninja 4
Bottom--DxO 9/Prime NR
Rob
