Originally posted by jackassp When using K-5 in various modes, with auto ISO set, when you pop up the built-in flash, auto ISO shows the selected ISO setting for your shot, before you pull the trigger (top LCD, screen and in the viewfinder) - same as when NOT using a pop-up flash.
K-3 however behaves differently, when the flash is popped up, the screen, LCD and viewfinder all change to "Auto" from the previous numeric value. You can't see what ISO you will get (in ISO auto mode) until after the shot is taken, unless you change to manual iso by selecting a value.
Curiously, the K-3 selects a much lower iso value than the K-5 ever did, resulting in a much better shot most of the time.
Not seeing the actual iso value is annoying IMO.
My question is: is the K-5 behaviour better? or the K-3 behaviour? The resulting K-3 shots do seem much better.
What do other people think?
Jack.
If you think about it how in a probably working pre flash system know what ISO you'll be using before assessing the flash required?
So I think what happens now is
1 no iso set - shows auto
2 preflash
3 iso set
4 main flash
5 correctly exposed image
There is no where in this to show you ISO prior to th shot being taken.
