11-26-2014, 12:37 PM   #16
Did you read page 49 of the manual?
11-26-2014, 06:03 PM   #17
Ummmmm....I thought 3 I bought on Ebay didnt work on my K30 !
That was before I turned it on and enabled it in settings ?
I bought a total of 3 for $1.99 each.......then I figured out that reading the manual might enable them....lol
They work just fine.
11-27-2014, 01:42 PM   #18
OK, I have been to page 49 and found the setting on the camera.
When it is enabled in the camera, the red light on the front of the camera flashes.
But the IR transmitter still does nothing. Maybe the K3 needs a different type. It looks exactly like the one sold on Amazon "for K3" and the battery checks at 3.3V.
11-27-2014, 02:22 PM   #19
Note that the rear sensor is very insensitive, the remote need to be very close. The front sensor will work from a much greater distance.
11-28-2014, 04:54 AM   #20
Clearly there are differences among the very similarly looking IR triggers, because the one I have certainly doesn't work with the K3.
I have a Yongnuo radio trigger so I am not too bothered but the IR method is nice because the camera end is self contained.
Can anyone point out a trigger which definitely works on their K3?
11-28-2014, 05:01 AM   #21
ShutterBOT
For the ones having phones with ir blaster, you could try this one too and confirm whether it works or not.
https://play.google.com/store/apps/details?id=com.c2nova.shutterbot&hl=en
12-02-2014, 04:44 PM   #22
emalvick's Avatar
QuoteOriginally posted by akshay869 Quote
I have an HTC One M8 and use a similar app that has a built in setting for Pentax cameras. It works for my K3 and K5. It's made by Power7.net (the app developer as identified on Google Play).
I'm not sure that the app has to be phone specific, but they do make ones that appear to be for HTC and Samsung. I have not tested my old Pentax IR remote, but I assume it would work since it worked with my K5.
12-02-2014, 06:12 PM   #23
I can now confirm that both of these work with the K-x, K7, Q, and the K3.
The smaller one does shutter only, the larger shutter + AF.
PENTAX Q  Photo
04-20-2017, 11:56 PM   #24
davinci's Avatar
I have a cheap JJC remote that works fine with my K3ii but my problem is that after a minute the camera gets in a sleep mode and I have to press halfway the shutter button to restart the ir remote function. How can I disable or extend this period?
Στάλθηκε από το HUAWEI VNS-L21 μου χρησιμοποιώντας Tapatalk
dslr, ir, k-3, k3, pentax k-3, remote, remotes
IR remote wont work on K-01 slackercruster Pentax K-01 19 02-26-2013 05:59 AM
Problem w/K-5 & wireless remote (not IR remote) RockvilleBob Troubleshooting and Beginner Help 2 02-15-2013 01:20 PM
Programmable IR Remote for K-5 v5planet Pentax Camera and Field Accessories 8 12-28-2012 03:57 PM
Bracketing with IR remote K-30 LoPing Troubleshooting and Beginner Help 5 07-18-2012 10:06 AM
K20D will only expose for 0.6 seconds in bulb mode using cheap IR remote fuent104 Pentax DSLR Discussion 4 02-10-2012 08:44 PM
All times are GMT -7. The time now is 05:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
