01-20-2014, 02:24 PM - 1 Like   #1
Paul the Sunman's Avatar
What the switchable AA filter needs to become truly useful is ...
... the ability to bracket Off/1/2.
I bet most of us leave the AA filter off on the K3, because we want the added sharpness, and because moire is relatively rare in most circumstances. You don't know it's there until after the shot, and probably until you get home and view your images on a big screen. The switchable AA filter is the "headline act" of the K3; it's what excited all the initial press interest. But it's no use if it's turned off. What would be truly useful is if we could bracket the AA filter turned off and on, and ideally write the files to separate cards. Then we need only import the second card if we notice moire in a shot.
Easily done with a firmware update?
01-20-2014, 02:26 PM   #2
QuoteOriginally posted by Paul the Sunman Quote
Yeah, and seems obvious. Surprised it wasn't included...
01-20-2014, 05:00 PM   #3
JimmyDranox's Avatar
Very good idea. You can post it here, to be in the Adam's attention, maybe he will tell this to Ricoh officials when he will meet them at CP+.
https://www.pentaxforums.com/forums/137-photographic-industry-professionals/2...ggestions.html
01-21-2014, 10:44 AM   #4
+1.
You forum members with more experience, could you please advise what we should do (in the context of this forum) to get this idea through to Pentax for their consideration?
Thank you.
01-21-2014, 10:50 AM   #5
It is just one of those things you KNOW they thought of, so the question is why isn't it there in the first place? Maybe there is a technical reason...
01-21-2014, 11:18 AM   #6
Perhaps there is a technical difficulty, but I don't see why. On the one hand, the K3 manual (p 80) states that the AA filter is incompatible with HDR capture, which is a type of bracketing. However, it seems to be allowed with normal exposure bracketing.
01-21-2014, 11:21 AM   #7
Something to do with timing, maybe it needs too long to set-up or something, but does seem like it could manage to go from full-on -> half-on -> off in a burst...
01-21-2014, 12:41 PM   #8
Or if it was an option, as the highlights alert on the LCD, which would appear moire alert on camera lcd. (google translate)
02-04-2014, 01:58 PM   #9
AA bracketing arrives!
No sooner said that done. Pentax K-3 firmware update 1.02 has introduced AA bracketing! It was an odd omission in the first place, but good to see someone's on the ball.
See this thread: https://www.pentaxforums.com/forums/172-pentax-k-3/250538-new-firmware-v-1-02-a.html
02-04-2014, 03:17 PM   #10
Awesome! Now I just have to buy one of those K-3!
02-04-2014, 04:15 PM   #11
This is a good news from many points of view. And is very encouraging for present and future owners of Pentax cameras. Second upgrade in 3 month, including a new function that is absolutely unique. That's a very good. I just wait to see what will come this Thursday.
02-05-2014, 08:47 AM   #12
jpzk's Avatar
What exactly is the " switchable AA bracketing" ... ? Maybe a dumb question but I'd like to know what it does/will do.
JP
02-05-2014, 08:58 AM   #13
JinDesu's Avatar
QuoteOriginally posted by jpzk Quote
JP
Allow you to shoot a set of 3 shots with AA on high, AA on low, and AA off with one button press. This way if you aren't sure if moire will show, you get 3 shots to choose from.
02-05-2014, 09:04 AM   #14
JP
The K-3 has no AA filter -- it uses the shake reduction mechanism to simulate one if you want. It has 3 settings -- off, mild, strong (I don't know what they are actually called). The new firmware allows to you automatically shoot a series of three shots, one at each setting. So since most people's general preference would be to leave it off for maximum sharpness and only turn it on if needed to avoid moire, now if you encounter a scene where you are unsure if moire is going to be a problem, you can turn on AA bracketing and figure out which looks best later in post-production without having to laboriously manually turn it to multiple settings for each shot.
02-05-2014, 10:39 AM   #15
jpzk's Avatar
QuoteOriginally posted by JinDesu Quote
The K-3 has no AA filter -- it uses the shake reduction mechanism to simulate one if you want. It has 3 settings -- off, mild, strong (I don't know what they are actually called). The new firmware allows to you automatically shoot a series of three shots, one at each setting. So since most people's general preference would be to leave it off for maximum sharpness and only turn it on if needed to avoid moire, now if you encounter a scene where you are unsure if moire is going to be a problem, you can turn on AA bracketing and figure out which looks later in post-production without having to laboriously manually turning it to multiple settings for each shot.
Thanks for the explanation!
I wasn't sure if this would be such a great thing to have but it seems that way.
Mind you, I seldom have used bracketing ... a couple of times for "trial" but no fancy stuff.
Cheers!
JP
bracket, dslr, filter, k-3, k3, pentax k-3, shot, switchable aa filter
Does the switchable AA filter pose difficult problems for RAW converters? Paul the Sunman Pentax K-3 & K-3 II 12 01-20-2014 02:10 PM
What's more useful, a hood or a filter? Fat Albert Troubleshooting and Beginner Help 28 07-22-2013 11:46 AM
Is it possible to remove the AA filter from a DSLR? TropicalMonkey Pentax DSLR Discussion 7 04-30-2013 12:32 PM
low pass filter the same as an AA filter ? dh4412 Troubleshooting and Beginner Help 12 10-15-2012 05:12 AM
What does an AA-filter do? DaveHolmes Troubleshooting and Beginner Help 2 09-10-2012 03:34 PM
All times are GMT -7. The time now is 03:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
