Originally posted by interested_observer The one item that I wish Pentax would change on their default setup is to have "use aperture ring" enabled. It makes no difference when using any of the auto aperture lenses, and you only set it once when you get a new body. But, it creates problems such as this when its not set.
I can give you a reason why I like to have use aperture ring setting disabled ....
I have no Non-A lenses, only A, FA and DA. At one point in time, I enabled "use aperture ring" and played with it for a while. Found I liked using the wheel better, forgot about the setting. Many months later, I put an FA lens on, inadvertently bumping the ring from A. Took me quite a while to figure why I could not adjust the aperture with the wheel, a large F--- on the screen would have told me the issue as soon as I placed the lens on the body.
It may not be a good reason, but it's a reason.
