02-05-2014, 03:52 PM   #16
At this point we must isolate the problem down to type of batteries. We know that there has been a problem with the AA NmH batteries. Now when you report in be sure and mention AA or the standard D-L190 battery. Grok and Skipper. Which batteries are you using?
02-05-2014, 04:27 PM   #17
for the record -
D-L190 in camera, Sanyo Eneloops in grip, batery type=auto, preference=grip first - camera reported battery depletion and turned off even though batteries in grip were charged. Had to turn back on and changed settings to:
D-L190 in camera, Sanyo Eneloops in grip, battery type = NiMh, preference=grip first - camera working fine so far; haven't depleted grip yet so not sure if it will automatically switch to camera when grip batteries become depleted.
I have not had the power on issue reported in the other post.
02-05-2014, 11:30 PM   #18
SkipperRi's Avatar
QuoteOriginally posted by gosman Quote
Both D-L190. Main battery is Pentax genuine, second in the grip is one from the eBay, that I've been using in my old Pentax K-7. Without problems so far.
02-13-2014, 10:14 PM   #19
I'm happy to report today that my battery grip with AA Tenergy Premium 2500 mAh Ni-MH rechargeables successfully handed off to the body battery with no hesitation! I'll try the D-L190 now in the grip and see how that works. I must say that I liked the heft created by the 6 AAs in the grip. Made if feel very pro like and stable handling the big lens!
07-03-2014, 10:40 AM   #20
K-3 grip aa depleted, inconsistent
Hi All,
I am having really strange behavior on my brand new (B&H bundled) grip with K-3
(no battery in camera body)
Grip with 6 fresh alkaline AAs (tested 1.4v, 5a each) has shown 1 bar of battery left
Inserting the holder with main pentax battery into the grip shows 100%
(with main battery in the body and AAs in grip, grip-first setting)
Playing with battery settings (auto to alkaline and auto detect, turning camera on and off) is showing: battery depleted, one bar, of 100% randomly
I have upgraded to firmware 1.03, same behavior
This could be
1) defective voltage sensor (but is it not the same sensor used when main battery is in the grip??)
2) software bug
3) bad contact (maybe)
I see some issues with grip power posted, but not quite the same. Is anybody having the same issue?
Thanks,
Julian
07-03-2014, 11:00 AM   #21
awaldram's Avatar
QuoteOriginally posted by julianrz Quote
Hi All,
This could be
2) software bug
Thanks,
Julian
Your description implies the batteries cannot sustain a reasonable voltage under load which is quite common fro Alkaline batteries.
Alkalones are really a stop gap when the chioce is nothing or alkalines , You will never get reasonable run times out of them as they will faill early even though potentially only partially discharged.
It's an issue with alkaline technolgy and hi drain not a camera issue.
07-03-2014, 12:36 PM   #22
Otis Memorial Pentaxian
Your setup is new, why not just give Ricoh support a call and ask their advice?
05-16-2016, 05:52 PM   #23
What is the correct number at Ricoh to call for this issue?
I bought a K-3, and a brand new D-BG5 battery grip from Adorama. When the battery grip is used with rechargeable batteries (that work fine in my K-5ii with D-BG4 battery grip) the on-off button on the grip will not turn the camera on or off. I have firmware version 1.21.
05-16-2016, 06:37 PM   #24
QuoteOriginally posted by virtualjsk Quote
Their Web site has both a toll-free telephone listing and a link for online chat. If there is some fine point related to using your grip, they should be able to help.
Customer Care | Ricoh Imaging
05-17-2016, 09:25 AM   #25
I never saw any issue with grip batteries since updating firmware
05-22-2016, 10:51 AM   #26
K-3 D-BG5 Battery Grip Power Switch
After a closer reading of the manual, I found this comment on page 13:
Memo
"It is recommended to turn off the battery grip when using the camera in a position other than the vertical position as the switch may accidentally be pressed."
This all makes more sense - the power switch on the battery grip only turns the grip on or off, and is not meant to turn the camera on or off.
That'll teach me.
06-03-2016, 01:38 PM   #27
slip's Avatar
my "fuel" indicator goes to around 50% really fast but stays at that spot a long time. firmware 1.21 with grip
Randy
batteries, battery, battery grip, battery grip battery, camera, dslr, grip, k-3, k3, pentax k-3, power, power source selection, reports battery grip, source, switch
battery grip for K-3 fialdj Pentax K-3 & K-3 II 3 04-06-2014 06:27 AM
Day bag for k-3 with battery grip? alwaysmichellerene Pentax K-3 & K-3 II 22 02-12-2014 01:37 AM
Pentax K-5 D-BG4 Battery Grip on a K-3, really possible? pentaxmz Pentax K-3 & K-3 II 8 12-02-2013 05:55 PM
For Sale - Sold: Pentax D-BG4 Battery Grip for Pentax K-7 & K-5 with Battery djrocks66 Sold Items 4 08-11-2013 08:10 AM
For Sale - Sold: Pentax D-BG4 Battery Grip for K-5 / K-7 w/D-Li90 battery Adam Sold Items 3 05-31-2013 01:05 PM
All times are GMT -7. The time now is 04:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
