Originally posted by karro I don't know. if the theory holds true: either that OR the firmware, which "underclocks" the machine, but that would be cheating of sorts (all claims about the enormous speed would need to be reviewed), and I'm not sure, the firmware actually controls the speed of the mirror mechanism.
It's a tough one even if true as I doubt they can lower the IR of the battery so it can absorb load fluctuations better.
Though given the issue seem to be a minority maybe it not so much fix the battery as grade them prior to use.
I used to work for a very large computer manafacturer we had a Mother board design that used to actually hit the cas and ras refresh specs of the memmory.
The result was first shipments had unacceptable failure rates with crashes and lockups common. We were already using the fastest memmory of the day so the solution was to limit suppliers to those who could build memmory to the spec they claimed (about 30% of our approved suppliers) and set up in house quality testing rather than trust 3rd parties.
Failure rates went from 8% to 1% inside 12 months.
It's an expensive option and Ricoh would need to be certain that was the only issue and that it was viable to grade the batteries.
Even if it was the issue it might be cheaper to fix on fail much to the customers frustration.!
I still think there must be a k3 body component as if I use some known worn out batteries from 2010 in my k3 it can be pursuaded to lock up but refuses to flop.
