04-26-2014, 07:39 AM   #1
MetteHHH's Avatar
K3 and the 1.7x AF adapter?
Hello wise forumusers!
I received my K3 yesterday after the seemingly endless week spent cameraless since I dropped my K5 on the tarmac.
I broke my DA* 300mm too, so while I wait for its replacement, I wanted to try out my ancient 300mm f4 SMC lens in combination with my 1.7 AF converter. But the camera doesn't seem to register the lens at all...
I seem to recall having to set the focal distance manually on the K5 when using the converter - but here I am not prompted for a focal length. The camera simply behaves like no lens is mounted.
I think I must have forgotten some setting that needs to be changed, but I can't find anything in the manual. So I turn to you - because usually someone in here ALWAYS knows what to do!
04-26-2014, 07:57 AM   #2
delegopa's Avatar
I dont know how it's called on the K-3 but you have to enable triggering without the aperture ring in A(utomatic) position. Its the last setting in the K-30.
Edit:
Here are far more details on it: https://www.pentaxforums.com/forums/58-pentax-beginners-corner-q/110658-using...x-dslrs-f.html
04-26-2014, 08:08 AM   #3
crewl1's Avatar
Custom menu #26 - set use aperture ring to 2.
04-26-2014, 09:00 AM   #4
MetteHHH's Avatar
Thanks a bunch, both of you. Didn't think about the fact that aperture was manual...
04-27-2014, 10:11 AM   #5
Hi MetteHHH,
Did setting the camera to recognize the aperture ring solve the problem? To me, this doesn't make any sense. The AFA is recognized by Pentax DSLRs as an F series lens with no FL specified. Recognizing the aperture ring doesn't come into play with an F series lens since they are all "A" and AF compatible.
I think your problem is that SR is turned "Off". With the AFA mounted, when I turn SR off, the FL input screen does not appear when the camera is powered up, but with SR "On", the FL input screen always shows when the camera is powered up.
One more thing to remember when using your SMC 300/4 with the AFA. Make sure the aperture ring on the lens is set at f4. This gives you a max Av of f6.8 with the AFA. Pentax AF sensors start to get challenged when the max aperture approaches f8, and f6.8 is only about a half stop faster, so stopping down the lens, even just one stop, will probably cause the AF system to stop functioning, except in very bright light. One last edit: -- this caveat only applies to manual aperture lenses since they would normally be stopped down before acquiring AF lock. Any "A" compatible lens would have an automatic aperture actuation and would focus and meter wide open, then stop down just before the exposure.
BTW, congrats on your new K-3 -- sorry to hear about your K-5 and DA* 300. . .
Scott
300mm, af, camera, converter, dslr, k-3, k3, k5, lens, pentax k-3
Pentax F1.7X AF Adapter /Teleconverter with K3 & DA* 60-250mm Mark K5 Pentax K-3 & K-3 II 4 02-23-2014 10:48 PM
Is the SMC PENTAX F AF 1.7X ADAPTER Weather Sealed? brosen Pentax SLR Lens Discussion 9 01-06-2014 09:32 PM
For Sale - Sold: SMC Pentax-F 28mm 2.8 and 1.7x AF adapter Asahiflex Sold Items 8 07-07-2012 08:43 AM
All times are GMT -7. The time now is 03:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
