05-31-2014, 05:29 PM   #1
mail2richw's Avatar
K-3 sensors died
After only 3 months of owning this lovely camera it seems that the sensor died. When I take a picture nothing shows on the lcd screen. In the play back review mode no pictures show. When the sd card is plugged into a PC there are squares that represent the images but they are all black. I did hard reset on all settings in the menu, and the menu show on the lcd which means that the lcd is working. Metering functions which indicates that light levels are entering the camera - just nothing is recorded. I've swapped around sd cards and did just about everything I can think of the limit it down to the sensor defect. I pulled out the battery and waited a long while, reinstalled and started the camera - no luck there.
Anyone have suggestions for me to try before sending it out? TIA
05-31-2014, 06:10 PM   #2
Paul the Sunman's Avatar
Have you tried it with fully manual exposure? Just in case it is grossly underexposing. However, either way, sounds like a warranty job. I haven't heard of this problem before.
Was there EXIF information attached to the "images"? Might give a clue.
05-31-2014, 06:34 PM - 1 Like   #3
VisualDarkness's Avatar
Check what happens if you shoot without a lens. Does the mirror move? Does the shutter open? What happens in live view without a lens?
05-31-2014, 06:57 PM   #4
jatrax's Avatar
Try a different lens if possible.
Try all manual exposure to make sure nothing is set wrong.
Check to see that your lens is stopping down properly at the time of shooting.
Make sure the lens cap is off.............
05-31-2014, 07:11 PM   #5
QuoteOriginally posted by mail2richw Quote
Hmmm... metering is working. Have you tried shooting with a manually set aperture via aperture ring? Don't think it'd actually work though. I'd send it in.
05-31-2014, 07:46 PM   #6
jpzk's Avatar
OMG !!
I hope this wasn't the problem!
JP
05-31-2014, 08:06 PM   #7
Have you tried reformatting the SD card in the camera?
05-31-2014, 08:50 PM   #8
mail2richw's Avatar
QuoteOriginally posted by Paul the Sunman Quote
Looks like the shutter isn't opening after following advise below. The ext inf is normal with shutter speed, iso, aperture, focal length and all. Thanks for the reply. It helps when others chime in. Being upset sometimes clouds the thought process.
---------- Post added 05-31-14 at 11:52 PM ----------
QuoteOriginally posted by VisualDarkness Quote
Thank you for this. I did remove the lens and noticed the mirror lifting but the shutter is not opening. I wonder if I should change my thread title? Anyway your help is greatly appreciated.
---------- Post added 05-31-14 at 11:53 PM ----------
QuoteOriginally posted by IchabodCrane Quote
Yes, it appears to be the shutter not opening.
05-31-2014, 09:09 PM   #9
Trudger1272's Avatar
I had a similar experience yesterday, but I figured it out after some investigation. What apparently happened was while shooting I mistakenly hit the EV button and unknowingly readjusted some things(with the rear e-dial)to make my camera seriously underexpose my shots to where they were almost black. Maybe a different situation, I don't know. But the end results were very similar to what you described.
05-31-2014, 09:40 PM   #10
Is there any live view image? More of an inquiry than anything.
It seems to be a 'return to base' asap.
AB
05-31-2014, 09:50 PM   #11
mail2richw's Avatar
no live view
06-01-2014, 12:42 AM   #12
Otis Memorial Pentaxian
no live view
Bummer. Time to contact Ricoh for a warranty exchange.
If it is any consolation, my original Canon G2 (ancient history, I know, but an expensive camera at the time) developed a dead rear LCD about four months after I bought it back in 2002. The defective screen was replaced under warranty by Canon and the camera has operated flawlessly ever since.
06-01-2014, 06:57 AM   #13
Sounds like the shutter is jammed, bummer.
06-01-2014, 07:12 AM   #14
mail2richw's Avatar
VisualDarkness Your advise landed me to this proper conclusion. I guess it is better than a dead sensor but amounts to the same result - no pictures. Thanks again!
My purchase was made from B&H in New York City. I'll call there first to see if I can return it through them or direct to Ricoh. Today I'll be loading battery into the K-5.
camera, died, dslr, k-3, k3, lcd, lens, menu, mirror, pentax k-3, pm, post, sd, sensor, shutter
K-5 Main Circuit Board Died Alan Granger Pentax K-5 & K-5 II 6 12-01-2013 07:04 PM
A tale of 3 sensors K-3/K-01/K-7 Painter Pentax K-3 & K-3 II 21 11-16-2013 09:38 PM
K-30 # of AF sensors used scottike Troubleshooting and Beginner Help 5 07-01-2013 08:51 PM
K-5II autofocus sensors - explanation wanted hjb981 Pentax K-5 & K-5 II 55 09-27-2012 04:27 PM
Sony now making 4/3 sensors ElrondElensar Canon, Nikon, Sony, and Other Camera Brands 10 07-07-2012 02:43 PM
All times are GMT -7. The time now is 09:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
