Hi,
there are two ways to control your 360 with the K-3.
1-set the camera to manual flash power, and the flash to slave (I believe it's slave 2). then the flash will fire in sync with the camera flash, which will contribute to the exposure.
2-set the camera to wireless master or control (which is what you appear to be doing) and the flash to wireless PTTL (slave 1). also set the flash to first curtain. The camera flash will fire to control the 360 and will contribute to the exposure if used in Master only.
If used in Control it should not contribute to the exposure, are you sure that what you are seeing are not the pre-flashes? It should be possible (in front of a mirror for instance) to verify if your flash is actually firing during the exposure.
