07-14-2014, 07:14 PM   #1
Lens correction and firmware update
I recently updated my K3 with the new firmware. I noticed that all of my lens corrections went to "0". Is that typical for firmware updates or could there another cause for loosing the lens corrections that I had in the camera.
07-14-2014, 08:26 PM   #2
The firmware update may have reset all the values. I noticed that one of my lens was reset to 0 as well but I didn't think much about it at the time. Now that you mention this I will have to take a look because the same thing probably happened to me and I will have to go through and retune all my lenses. Thanks for posting this before I took too many photos with AF adjustments that were reset.
07-14-2014, 08:57 PM   #3
Be careful with that, though. I noticed that after one of the firmware updates I no longer needed as many of the fine adjustments that I did originally. I had several lenses that needed adjustments at one time. I think I may have one now, and I'm not sure I even have that.
07-14-2014, 09:41 PM   #4
lense corrction and firmware update.
I went through them and they all needed about the same as before. The reason I caught it was the some photos were not a sharp as they should have been. I decided to check the lens correction and they were all at zero. There is no other reason that I can think of that would have caused them to reset to default other then the firmware update. If this really was the cause then I would think that Pentax would make mention of that.
correction and firmware, corrections, dslr, firmware, k-3, k3, lens, lens correction, pentax k-3
Rumoured K-3 f/w update: diffraction correction and mirror flap improvement JPT Pentax K-3 & K-3 II 42 07-11-2014 10:34 AM
Firmware 1.13 update stopped AF working on one lens only TimFAu Pentax K-r 5 09-25-2013 12:41 AM
k100d firmware update/takumar lens PentaxPilot Troubleshooting and Beginner Help 4 12-08-2009 07:40 PM
Firmware update and file number luxart Pentax DSLR Discussion 7 01-26-2007 07:13 PM
firmware update for K100D/K110D and others WMBP Pentax DSLR Discussion 15 12-29-2006 10:18 AM
All times are GMT -7. The time now is 10:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
