Originally posted by jatrax Thanks, but I don't think it's working for me. I've tried everything I can think of and I get the same exposure at full as I do at 1/128 power. I'm sure I am doing something wrong, but no idea what.
k-3 in 'M' mode, flash in 'M' mode AF-200fg flash in 'Auto' setting. The k-3 screen changes to show what it thinks is going to happen (FULL or 1/128) but the flash duration is the same and the exposure is the same.
If you have not already make sure the shutter speed is under 1/160 or the flash will not fire.
If you are in X mode then the shutter will lock to 1/180, which actually makes me wonder. What happens when you put it in X mode, still the same result?
Edit:
Actually re-reading your post.
You are getting the flash to fire but you cannot get the flash to fire on anything but full power?
I have never used the AF-200FG but I do have Yonynuo flashes and you can definately change the power output of the flashes while in manual mode.
