08-12-2014, 05:35 AM   #1
Will the k-3 take the AA battery adapter or do I need to purchase a battery grip
Just wondering if the K-3 will take AA's in the body like my k-50 or is the only way to use AA's is by using the battery grip. Sadly I am now without my k-50 while it gets repaired and trying to decide if the K-3 is worth the big bucks or should I just get another k-50 which hubby said he would be happy to use on occasion.
08-12-2014, 05:39 AM   #2
There's no AA adapter. I find it simpler just get a couple extra batteries especially they last way longer than AA.
08-12-2014, 05:42 AM   #3
QuoteOriginally posted by ruggiex Quote
Cheers odd not the findings I had with my K-50 plus travelling where there is no charging points so buying batteries was going to be easier. Guess it is another k-50. Thank you for your speedy reply much appreciated.
08-12-2014, 08:45 AM   #4
Not sure if the standard battery last longer. Six Lithium AA batteries in the grip lasted several thousand images for me.
08-12-2014, 09:08 AM   #5
kkoether's Avatar
QuoteOriginally posted by StigVidar Quote
I'll second that number of shots on the AA in the K-3 grip. I use Sanyo Eneloop's in the grip. I've gotten over 3500 shots in a day on one of the standard K-3 lithium batteries also. I've been very happy with battery life on my K-3. Between the 2 standard lithium batteries I have and one set of charged Eneloop's I could theoretically shoot near 10,000 shots in one day without having to charge any batteries.
08-12-2014, 09:40 AM   #6
Well Lithium AA definitely last a lot longer and there are 6 of them in the grip... Regular AA in the grip will definitely last longer too, again, the total capacity is higher. However, a grip adds a lot of bulk and weight that is constantly on the camera. For me, a grip doesn't serve a lot of purpose other than carrying extra battery so it's much easier to just carry 2 extra regular batteries in the bag.
08-12-2014, 03:22 PM   #7
Thanks guys I use the eneloops as well I have for a long time just so easy but nice to have the option if I can't recharge I just go buy a set from somewhere. Think it will be another k-50 but going to be so miffed if a new camera in this range is released next month oh well guess I sell one of them then upgrade 😁
08-13-2014, 02:04 AM   #8
awaldram's Avatar
Not strictly true
standard AA have a droopy discharge Voltage and once that voltage drops below around 6v the camera will stop even though the AA's will still be around 1/2 charge
with NiMh and eneloops things will be better due to the Voltage holding up but have less power than the dli-90 due to lower terminal voltage (more cells greater internal resistance lower load voltage) from full charge .
At best eneloops will match a single DLi90 but on average the lithium battery will outperform the aa's under heavy load (shutter, AF , video etc )
Your point on lithium AA's is probably valid but given their cost you could just put and extra DLi-90 in the grip and buy a couple of beers with the change
Also consider the K50 takes the dli109 a small battery designed to allow a aa module to be fitted this battery can deliver somewhere around 6.5 W/h the dli90 is aorund 14 W/h
12-12-2014, 01:08 AM   #9
Just buy a couple of these. They are DSTE made in China. Maybe not the very best , but then again not the elcheapo china crap either. Ive used this guy 4 times for 3 diffrent cameras...not a problem ever..... 2pcs DSTE D LI90 Rechargeable Battery for Pentax K 01 K 3 K 5 K 5 II K 7 | eBay
Thry run about $13 for two including shipping. And NO....hes not my brother , or friend....just got lucky and stumbled across him on Ebay....... USA located and ships fast and free !
And if you do get the Vertical/Battery grip.....Its got a couple features that I liked.
#1......a place for the Body contact cover to go in the grip so it isnt lost.
#2....a place in the grip for the rubber body plug so it doesnt get lost.
#3.....Comes with 2 inserts , one for battery , and one for AA (6 Batteries).
#4.....A spot to put a spare SD card just in case....nice !
I got mine from Tri-State1 on Ebay for $135 shipped....NIB.
battery, battery adapter, dslr, grip, k-3, k-50, k3, pentax k-3, purchase a battery
The need for a battery grip bassek Pentax DSLR Discussion 34 06-08-2014 04:15 PM
Purchase the Battery grip contacts cover for the K-3 brosen Pentax K-3 & K-3 II 2 12-18-2013 09:59 PM
Looking for a Battery Grip for the K-3 (D-BG-5) any idea where to buy one in stock? brosen Pentax K-3 & K-3 II 2 12-17-2013 06:15 PM
Do I really need a flash/battery grip? paolojackson Flashes, Lighting, and Studio 17 12-17-2007 03:52 PM
All times are GMT -7. The time now is 10:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
