Yes, but with one caution. Several years before Pentax developed the auto-focus version of the K-mount, Ricoh made a series of program mode cameras that used a special variation on the K-mount. Instead of the array of contacts on the mount face used by Pentax, the Ricoh system used a single pin-like contact. The Ricoh lenses having this contact are labeled "Rikenon P". Ricoh was a popular brand at the time and most third-party lens makers made K-mount lenses having the "P" contact and some made a combination Pentax "A" and Ricoh "P" mount that supported both systems.
Are we bored yet? The exciting part comes a few years later when Pentax brings their second-generation auto-focus system to market using a mechanical drive pawl on the lens mount. By unfortunate coincidence, the well for the AF drive was (and continues to be) at the same location as the Ricoh pin contact. Did I mention that the pin is spring-loaded? As a result,
mounting a lens with the pin on a Pentax AF body results in the pin extending into the AF well and effectively locking the lens onto the camera. Not Good.
But, wait, there's more! There are two versions of the Ricoh pin contact. One is a spring-loaded pin and the other is a smooth-headed spring-loaded ball. The ball type is much less likely to jam into the AF well.
So, with the history lesson over, here are the bullet points:
- The "Ricoh Pin" is something to be aware of when buying vintage K-mount lenses
- Lenses having the "Ricoh Pin" are not uncommon and are generally labeled KR, KPR, or something similar on the lens body or on the mount itself
- Ricoh brand lenses having the pin are always labeled "Rikenon P". Other Ricoh lenses (XR Rikenon and Rikenon) are quite safe.
- The "Ricoh Pin" is limited to manual focus lenses
- For articles and images showing what the pin contact looks like and how to find it, search for "Ricoh Pin" on your favorite Internet search service
- No current lenses are being sold in the Ricoh "P" mount
- The rounded-type contact is generally considered to be safe. I have a Rikenon P 50mm lens that I have used on my K-3 with no problems. Having shared that information, I must caution that another lens might not work so well.
- The conventional solution to solve the incompatibility is to surgically remove the pin from the lens
- If you accidentally mount a "pin" lens to your camera, removal is difficult. Again, Google is our friend. So is Pentax Forums. A hacksaw may be required.
