Originally posted by Badger Logic Any advice or comments are welcomed. I am a retired teacher. I have a fair eye for composition. I am a writer and like to use my photos to help illustrate my work. I can take criticism. I have the ability to laugh at myself and my limitations. I look forward to making your acquaintance.
Robert "Badger Logic" Thomasson
Elbert, Colorado
Hi Robert, Ross here - from NZ, I also enjoy landscapes, and own a K3 and a number of lenses.
The K3 is going to be a big step up from your Kx in terms of functionality and the image quality. It will take some time to get used to. I stepped up from a K5, and there was still a learning curve. A couple of nice things you will find using the K3 - firstly enjoy using it with the AA filter off - you will find your images are a lot shaper, second - since you work in low light - the K3 is quite useable up to ISO6400, so you will find that quite useful compared with the Kx.
With regard to lenses - what you have is what you have, and any lens is better than no lens. If you are looking to purchase some different lenses I have found the Pentax DA Limited wide lenses - the 15mm and the 21mm are very good for landscapes. Both render differently - if I had to choose one it would be the 15mm.
I do a lot of my landscape photography now with a Zeiss 35mm f2 - the focal length is equal to approximately 50mm on full frame, but it still works very well for landscapes. I used to have the DA35mm Macro Limited, and again it is a very good lens and well worth considering. I found I would always grab the Zeiss if I was looking for a 35mm, so in the end I sold the DA35mm Limited, but it is still a very good lens.
If you look at your shooting records with your zoom, you will see which focal lengths that you favour, and that will help guide you if you move to prime lenses. You really can't miss with any of the Pentax Limited lenses - DA or FA, what you purchase really will be dependant on the size of your budget. One thing that is really nice about the DA Limited is they are small and light, which is great when you are hiking.
I am sure you will really enjoy your K3.
All the best.
Ross
