Originally posted by dubsider Lens correction setting
(K3 v1.11)
the setting on the 1st menu tab is grayed out .. How does one enable this setting?
EDIT: figured it out. the setting did not activate with my Sigma DC 17-50mm EX HSM,, but did when I installed the Pentax 50-135. I would have thought the Sigma would be compatible.
Lens corrections are available only with modern Pentax lenses. If you shoot raw only, it can be left off. I shoot raw and apply the correction using Lightroom's lens profiles.
If you are using "consumer" kit zooms and shooting JPEG, it should be turned on. With DA* lenses and most likely Ltds you can turn it off.
