We have a K-3 which is 12 months plus about 2-3 weeks old. I could make the usual excuses about being too busy, but I didn't raise my concerns with Pentax within the warranty period. I will give them a call tomorrow (or the Oz distributor CR Kennedy here in Adelaide) to see if they will help me. Anyway, I thought I would mention the issues here to see if anyone has seen anything similar.
The first issue. On a few occasions I have seen the camera get into a mode where all images have a strange colour cast to them. Resetting the settings gets the camera back to normal. Investigating further, I used the Pentax DCU 5 software to look at RAW images. (I don't currently have any other software for this). In the Custom Image menu I noticed that the "good" images have the Bright setting (which is what the camera should have had), and "bad" images are all set to Cross Processing. It has occurred to me that I may have accidentally pressed keys on the back of the camera to change to cross processing (right arrow, then left arrow would do it). I think it's unlikely I would accidentally do this exact same thing maybe 4 times, but it's possible.
The second issue is more definite. While using the camera, it suddenly began continuously releasing the shutter at a rapid rate. I couldn't get it to stop, and even turning off the power switch didn't stop it. I had to remove the battery. On replacing the battery all was normal. I expected 100+ images to have been captured while the camera was doing this, but there were none, just the ones I had taken. This problem has never returned.
The camera was running FW 1.01 when issue 1 was seen. I then upgraded to 1.03, and don't recall if issue 1 was seen again. Issue 2 happened while runing 1.03. [EDIT - just cecked, and it's now up to 1.11! I didn't see anything relevant to my problems in the changes.]
Any thoughts on these things would be appreciated, thanks.
