Originally posted by Not a Number With manual focus lenses there is no focus lock on the half-shutter press or with the AF button. So moving the focus spot will re-detect focus as long as the meter is active. If you have AF.S set the shutter will not release unless focus confirmation is indicated. This is great for catch in focus. However you can only select the center focus spot with manual focus lenses. This means you can't focus on one spot and recompose the shot as you will lose focus confirmation. I either set AF off or I have my AF button set to disable AF which allows the shutter to release without focus confirmation indicated.
Are you using k-3 or k-5/IIs? The configuration setting is slightly different, as k-3 (there is AF1 mode and AF2 mode). In AF2 mode, the Half-press shutter does not activate AF, so basically negate CIF, but allow you to release shutter even though the previous focus point (using AF button) is no longer in focus. Typical use of AF2 is to use AF button to get focus point in focus (green hexagon) then move side way slight for re-composition, followed by shutter release. If you do it this way using manual focus lens, the degree of focus accuracy is in question as it depends much on how much you move side way to affect focus distance.
