Originally posted by forest_bear59 The two lenses You mentioned will not cause You any trouble, but they are not as comfortable to use - especially the zoom lens (at least if You use SR). Shake reduction with manual lenses namely works prompting You for the focal length of the lens when the camera is switched on. If You zoom afterwards, You have to correct this prompted value, which means to switch the camera off an then on again.
With my old 60-300mm zoom I have the same issue and decided to give it away and get the Pentax 55-300mm lens.
The good news is: You can try everything out and decide what is ok for You.
If you input the longest focal length of a zoom for SR, it works pretty well throughout the zoom range. Perhaps not as good as setting the precise focal length, but in my experience it is good enough.
