Show Printable Version 7 Likes Search this Thread
02-13-2015, 07:54 AM   #46
I would be a bit concerned with a strap that has the "quick detach" clips. I could see myself just fumbling with my fingers as I walk along not paying attention and accidentally clicking the clip and then my camera goes for a ride. I sure like the idea of quick interchangment though but couldn't take the chance.
02-13-2015, 08:08 AM   #47
amateur dirt farmer
pepperberry farm's Avatar
Peak Design Sling..... so comfortable and easily adjusted....
02-13-2015, 08:09 AM   #48
PFH
PFH's Avatar
I love the Peak Design Leash and Cuff.
02-13-2015, 08:29 AM   #49
QuoteOriginally posted by PFH Quote
Leash and Cuff Camera Straps - Kickstarter Video - YouTube
Heck yeah! Where do I get one?
02-13-2015, 08:38 AM   #50
amateur dirt farmer
QuoteOriginally posted by jayman_1975 Quote
B&H carries several Peak Designs' models:
Camera Straps | B&H Photo Video
02-13-2015, 11:18 PM   #51
jatrax's Avatar
If you mean the Op/tech, not gonna happen. Unless you are a lot stronger than I am no way are you going to accidentally open them. Hard to do intentionally to be honest, you really have to really squeeze.
02-14-2015, 01:02 AM   #52
I have doubts about these spider-net thin 'Peak Design Anchor Links' to attach straps to the body
QuoteOriginally posted by pepperberry farm Quote
02-14-2015, 02:28 AM   #53
PFH
PFH's Avatar
QuoteOriginally posted by Prakticant Quote
They are tested to withstand 100 pounds of pulling force. I trust them completely.
02-14-2015, 05:25 AM   #54
amateur dirt farmer
I can see that they'll wear over time (like any other connection point), but if you pay attention and replace them as needed, you won't worry about them.... I trust them implicitly...
02-14-2015, 11:02 AM   #55
Driline's Avatar
Thanks....I just ordered the Peak Design "Cuff" from Adorama. I have the Optech but this looks less obtrusive. And I liked Sigourney Weaver in the Youtube video.
02-20-2015, 08:58 AM   #56
zzeitg's Avatar
When using a sling strap (camera hanging on 1 point), what is the biggest lens that you guys consider as reasonable to put on?
I know that you could also fix the uni-loop to the lens plate, but I'm only wondering what is the max. lens size still safe to use when the camera is hung.
In different words - what is the carrying capacity of the camera K-mount?
02-20-2015, 11:42 AM   #57
lmd91343's Avatar
QuoteOriginally posted by zzeitg Quote
Who knows?
I've looked online for years for an authoritative answer to "how much weight can the tripod screw something could the tripod screw socket support?" in nikon, canon, and pentax lists. I've only heard anecdotal stories. The most I have done is a 50mm macro lens with the camera vertically attached to a copy stand.
The tripod socket is not just 1/4-20 threads tapped into a solid metal plate but rather just a collar, with threads, held fast to the camera structure by two or three small screws. Medium format cameras as light weight (lighter than a lens less DSLR) as a Zeiss Super Ikonta 645, has a beefier 3/8 tripod socket.
This has special significance to me. I had a Canon T90 and a Canon 200/2.8. Both were expensive. The metal neck strap loop on the camera broke, dropping the camera and lens two foot down to the sofa cushion. Whew! Lucky!
body, camera, dslr, k-3, k3, l-bracket, pentax k-3, straps
Camera Strap for the k30-k50 kshapero Pentax K-30 & K-50 37 04-12-2014 01:48 PM
Which Camera Body K-3 or K-50 WVRICK Pentax DSLR Discussion 30 01-23-2014 10:17 PM
Which battery for K-3 sharepointalex Pentax K-3 & K-3 II 28 12-24-2013 10:03 PM
k-3 sliver strap ljay1129 Pentax K-3 & K-3 II 5 11-08-2013 07:28 PM
Which camera Strap for k5? 10speeduk Pentax Camera and Field Accessories 20 08-06-2011 11:40 PM
All times are GMT -7. The time now is 05:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
