Originally posted by grispie that was also my thought at first. But i can imagine in a shoot, one sets the exposure manually & then for creative things or whatever one wants to change aperture up & down.e.g.
& I think he wants the camera to just automatically compensate back to the original exposure setting without having to fiddle himself. Hence AE.
But the camera chooses iso to compensate back. I think he wants it to use shutter.
Sure it must be possible.
---------- Post added 03-06-15 at 03:26 PM ----------
is it not an option then to use Av mode & put the auto iso range from "100 to 100"?
Hi grispie\
You are absolutely right on the first part. But instead of the shutter speed to compensate. I actually want the ISO to compensate. Not the shutter speed which the K-3 is behaving.
Cheers mate....
---------- Post added 03-06-15 at 08:48 PM ----------
Thanks sterretje. For the solution. It kinda work but still a bit hassle
Sorry if I have confused all fellow Pentaxian..... Its actually very simple and just because I am lazy and need a short cut to this.
Lets say we are in a banquet or a ball room. With a reasonable controlled lighting environment. I set my K-3 to 1/50th of a second shutter speed, Aperture f4 and ISO 2000. And with a crappy Yongnuo full manual no TTL nonsense flash. Was shooting all day and come to a scene where I need to open up the aperture for some "Bokeh", The normal procedure would be, first, drop f number, then press ISO button and compensate. Done. That is the usual steps I normally do.
This laziness came when I realize when using a Nikon D610, on M-Mode with manual ISO, I can actually AE lock the exposure and drop the Aperture, the camera will automatically compensate using ISO and by stops, not by metering with. 2 stop aperture, 2
I guess I could just use back the same old matter. Drop aperture, drop ISO. Up aperture, up ISO. No shortcuts... 2 stops down aperture, 2 stops down ISO. 2 stops up aperture, 2 stops up ISO and repeat repeat repeat and repeat.
Cheers everyone and sorry again for the confusion.
---------- Post added 03-06-15 at 08:54 PM ----------
Originally posted by stevebrot That does nothing in M-mode on the K-3
Well, then use the D610! The two cameras work differently. On the K-3 M-mode is strictly manual. There is no auto-ISO option in M-mode. The equivalent to M w/auto-ISO is TAv mode (not supported by Nikon). If you want to hold aperture/shutter settings and shift ISO for exposure comp, use M-mode and adjust the ISO up/down using the ISO button as is your preference.
I wish I could replace the K-3 with the D610. But the D610's auto focusing during low light without the help of the assist light is rubbish..... In this area, the K-3 Gangnam Style Danced in front of the D610. Often without even the needs of the AF Assist light. I guess AF assist light on the K-3 is just for decoration and a torch light if you really need it.
Cheers....
---------- Post added 03-06-15 at 08:56 PM ----------
Originally posted by emalvick And of course the problem with TAv mode as I think the OP noticed is that it doesn't play nice with flash.
I think he is just trying to do a bit too much and perhaps expecting everything to be exactly the same. Messing with the different modes, invoking the AE-lock, and then adjusting exposure parameters are going to conflict with each other.
You are absolutely right emalvick. Guess I need not to be lazy and work my fingers.....
Cheers mate
