Originally posted by PenTex Not if I want to capture slow moving clouds
Well, you can shoot up to 2000 frames, so as long as it's not high noon, you should get something interesting. Even with a 1/50s exposure, you can get an effective exposure of 40s - that's pretty good! Also, if you use interval shooting for "blurry cloud" shots, and your interval is much higher than the exposure time, you're likely to get a kind of "zebra effect" as lines of high contrast move in the sky. If you look carefully, you can see this in the following shot, which I took with the K-01's multi-exposure mode, where you have to fire each individual frame separately. As I recall each frame was a 4s exposure, and I waited maybe 4-5s between frames.
Look at the darkest cloud to the right of the frame, you'll see what I'm talking about. Had I shot this with a K-3, I would definitely have used a sequential multi-exposure rather than an interval composite...
