04-03-2015, 09:52 AM   #16
Otis Memorial Pentaxian
Maybe that setting is used for green button stop down metering on M42 glass?
I think so with some bodies. At least that is the common suggestion when people have M42 or series-K/M metering questions. Most (all?) of the flagship bodies default to this in M-mode when the A contacts cannot be detected, but some of the consumer-level bodies will not meter unless this is explicitly set.
04-03-2015, 10:12 AM   #17
QuoteOriginally posted by Biggzie Quote
Excellent ... that worked ... Thank you
---------- Post added 04-04-15 at 02:29 AM ----------
That depends on how you look at it, I find it not logical for the camera to change DOF while bracketing & that's the way every body has worked up to this.
I also find it annoying I couldn't find it easy in the manual or searching for help online.
I think the default of changing aperture does make sense. They have to assume that the camera is not on a tripod in which case bracketing via shutter speed change could produce blurry images. Much harder to live with than changing DOF (IMHO).
04-03-2015, 11:10 AM   #18
Note that with the latest v1.11 firmware update to the K-3, TaV mode will now bracket by default using the ISO and leave the shutter and aperture alone.
Jack
04-03-2015, 11:17 AM   #19
QuoteOriginally posted by IchabodCrane Quote
In many ways, yes. The general default behavior of the green button is to return the exposure to the program line or the "dumbed down" state. I have taught several people the basics of using their Pentax dSLRs and make a point this feature. To have it be different in M mode only would be inconsistent and potentially confusing.
04-03-2015, 11:18 AM   #20
QuoteOriginally posted by jbinpg Quote
Jack
I don't remember, how did it behave before?
(...not a big user of TAv mode...)
04-03-2015, 12:53 PM   #21
It followed the P line shift setting.
04-03-2015, 06:59 PM   #22
None of my film cameras does automatic bracketing, though my K10D worked the same as my K-3.
Your K-3 brackets from the initial reading and does not change between exposures even if the light changes.
I believe that the default setting for the green button in M mode on the K-5 is the program line. That is how it is on the K-3. I suspect that yours was moved to Tv shift at some point since that behavior makes good sense to many people who mostly use Av mode.
I haven't moved it with either of my K5 bodies or my K10 or K20 & yes I want consistent exposures even if the light changes in part of the image ...
---------- Post added 04-04-15 at 12:37 PM ----------
I agree ... That's why I didn't look there ... I wasn't aware that this would be the cause of my bracketing issues
Im usually in either Av or M mode & have used the Green button lots ... I haven't dragged the K5 bodies out to see what they are set to yet
04-03-2015, 08:34 PM   #23
I will be curious to see what you find. With any luck this problem will be solved for you. Like you, I had no idea that it would affect bracketing, though it sort of makes sense now that I see it. Your use case is very interesting and maybe even worth writing up as an article. It never occurred to me to use a fully manual setting as the start point for Av bracketing.
04-09-2015, 02:41 PM   #24
Yes that is the point, exposure is changing ... I have set the ISO, Aperture & shutter speed, then Ive asked the K3 to do a 5 shot bracket ... it is doing that, but I don't want the aperture or the metering to change.
I'm late to this party, but I'm not understanding this part about not wanting the exposure to change. That is what bracketing is...changing the exposure between shots so you can either find one better than what the meter originally thought should work; or to make an HDR image.
I think you're saying there is only one specific way you want the exposure to be changed between frames, but I'm not sure.
04-10-2017, 03:44 PM   #25
Can we go a little deeper with this topic? I shoot raw and want to do exposure bracketing so I can do exposure blending in PS. I did not like my aperture changing either because it affects the DOF in my expousre. I do see that I can set my camera to AV and the aperture and ISO are locked during bracketing. The only change is shutter speed. While I want my aperture locked, I am open to having the camera adjust both my shutter & ISO. When I go the E-Dial Programming, I have quite a few choices. I can find no explanation about what each choice does. Any thoughts or suggestions? Thanks!
04-11-2017, 09:28 AM   #26
QuoteOriginally posted by Lorrow Quote
This is an old (now zombie) thread. Here are a few comments:
  • Not all the comments and conclusions on this thread are fully accurate
  • The following modes allow fixed aperture auto-bracket with default e-dial settings, Av and TAv
  • Use fixed ISO and Av mode if you need sensitivity to remain the same
  • M mode is also supported, but not recommended. There are two fairly grievous bugs in the bracketing implementation. See this related thread:
    M Mode Anomalies: Adventures In Bracketland - PentaxForums.com
  • Care should be taken when doing a bracket at or near the limits for aperture, shutter speed, or ISO
  • The exposure shown in the viewfinder and LCD displays is the settings for the first exposure in the sequence. Depending on bracket order, it may or may not be the base exposure for the bracket.*
* It is for the default bracket order.
aperture, av, bodies, bracket, button, camera, change, dof, dslr, exp, exposure, iso, k-3, k3, k3 exposure bracketing, k5, menu, pentax k-3, people, post, shot, shutter, steve
Exposure Bracketing gordon_l34 Pentax K-3 & K-3 II 3 06-08-2014 05:48 AM
HDR vs. Exposure bracketing regislea Troubleshooting and Beginner Help 10 05-06-2014 05:27 PM
K5 iis exposure bracketing timer chickenandavocado Pentax K-5 & K-5 II 14 09-18-2013 06:19 PM
Exposure Bracketing mayday295 Photographic Technique 4 05-18-2013 01:28 PM
HDR/Multi-exposure/Exposure Bracketing sany Troubleshooting and Beginner Help 4 04-24-2011 08:52 PM
All times are GMT -7. The time now is 06:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
