04-24-2015, 10:15 AM   #1
Cambo's Avatar
K3ii in the studio
Does anyone know if the high rez mode will work with studio flash? That would make it the ultimate studio camera if so. But I imagine the processing takes longer than the normal flash duration. Perhaps we'll need to use video lights to use it.
It's a GREAT time to be a Pentaxian.
Cheers,
Cameron
04-24-2015, 10:35 AM   #2
QuoteOriginally posted by Cambo Quote
Cheers,
Cameron
I had sent Ricoh/Pentax a tweet about how they're implementing this mode, but no answer. Will be interesting to see if they use e-shutter, use full/compensated exposure (like multiple exposure mode), or some other method. I'm wondering, pessimistically, if they'll disable the hotshoe/sync port entirely like they do already for speeds faster than x-sync.
04-24-2015, 11:13 AM   #3
I imagine you would have to use continuous lighting. Firing a flash 4 times in succession in less than half a second or so would seem ambitious. Although studio strobes might be up to the job. It's been too long since my last real studio shoot to remember...
Wim
04-24-2015, 12:03 PM   #4
Solaire's Avatar
QuoteOriginally posted by Ishpuini Quote
It can be slower if Ricoh wants it to be slower.
04-24-2015, 12:20 PM   #5
And why would they want to intentionally make it slower?
04-24-2015, 12:39 PM   #6
bobell69's Avatar
Perhaps HSS mode could be modified to accomplish it.
04-24-2015, 01:15 PM   #7
Cheers,
Cameron
I was wondering about that too. My guess is that strobes are out unless pixel shift can be manually controlled and delayed to allow strobes to recycle to proper power levels.
I remember years ago Imacon had a back with multi-shot capability to increase resolution. Their implementation was actually a bunch of shots done manually allowing strobes to recycle to proper power levels. Hopefully Pentax will have a manual mode. Otherwise, gotta look into some LEDs for studio work.
04-24-2015, 02:21 PM - 1 Like   #8
Solaire's Avatar
Here's the full conversation:
Original: Flash cannot be used, because it cannot be fired 4 times under 0.5 seconds
My reply: Ricoh could make a slow version, just add a few sec between exposures
Your reply: Why make it slower?
04-24-2015, 02:30 PM   #9
All right, that's a valid scenario (assuming there aren't other issues with using flash with PSR). And I should pay more attention to the context.
For this version though, flash can't be used.
04-24-2015, 02:38 PM   #10
crewl1's Avatar
Looking at the sample of the girl on the Ricoh site it seems this feature would require additional post process work to smooth out skin imperfections. Zoom in on her lip and nose area. You can see all the pores and upper lip hair easily.
I would think it would be great for product work though.
04-24-2015, 02:44 PM   #11
The girl image was shot with Pixel Shift Resolution turned Off.
04-24-2015, 02:51 PM   #12
Otis Memorial Pentaxian
QuoteOriginally posted by crewl1 Quote
What he said. Only the first two of the example photos were done with PSR turned on. That being the case, I think it speaks highly for the K-3 native resolution without PSR.
04-24-2015, 03:04 PM   #13
crewl1's Avatar
Oh I thought they were all samples of the pixel shift. Never mind then.
04-25-2015, 04:43 AM   #14
Edgar_in_Indy's Avatar
So to use the feature, the camera needs to be on a tripod, and the subject needs to be still. Besides landscape shooting, the other most obvious application where you would have a tripod and a still subject would be product photography.
It's a shame if Pentax doesn't implement a feature to allow adjustment of the time between exposure shifts, so that flashes can recycle.
04-25-2015, 06:18 AM   #15
If will be possible time-shift with pixel-shift (for in-studio photography)
I can imagine even portrait/beauty shoot.
Just to need stacking (?) those four shoots manualy and remove part of image from three ones.
Im macro - too.
flash, pentax news, pentax rumors, studio
The k3ii is out... so what about the FF.. kooks Pentax Full Frame 31 05-17-2015 06:04 AM
Put Pentax FF on hold for the K3II Dlanor Sekao Pentax K-3 & K-3 II 30 04-27-2015 06:11 AM
Pixel Shifting Samples from Pentax on the K3II mikeodial Pentax DSLR Discussion 99 04-26-2015 05:00 PM
Who is using a 645z in the studio? xpixel Pentax Medium Format 23 01-06-2015 11:36 PM
Flowers - in studio and in the wild... igor Post Your Photos! 15 04-07-2009 10:22 AM
All times are GMT -7. The time now is 11:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
