05-15-2015, 07:14 AM   #1
narual's Avatar
K3 battery grip switch problem
Hi all!
When I first got the K3, the battery grip switch was very snappy. It was clearly on or off, and still worked fine for the preview function.
I don't use it all that often, but recently I noticed that there's no longer any resistance at all between on and off, to the point where it's shutting itself off just from brushing against my leg when I'm not actively using it. It still has a springing action for the preview function, but having it be off half the time I try to use it is a minor annoyance. More importantly, I'm concerned that it might be damaged since the change was so dramatic, almost like something might have snapped off inside.
Has anyone else had this problem? Is it worth losing the grip for who knows how long on a warranty repair?
05-15-2015, 08:25 AM   #2
BigMackCam's Avatar
I have the grip also, but haven't experienced the problem - the switch you mention feels the same as the one on the camera (actually, a little stiffer, probably because it doesn't get used so much). In your situation, given that you can keep and use the camera without the grip, I'd definitely send it for warranty repair. Hope you get it sorted.
battery, battery grip switch, dslr, function, grip, k-3, k3, k3 battery grip, pentax k-3, preview, switch
K3 3rd party battery grip lotech Pentax K-3 & K-3 II 9 12-29-2014 12:01 PM
K3 w/ battery grip package mail2richw Ask B&H Photo! 3 03-04-2014 02:16 AM
K3---K20 battery grip downunderman Pentax K-3 & K-3 II 3 12-06-2013 01:08 AM
K3 battery grip Jimlad Pentax DSLR Discussion 2 12-04-2013 01:52 PM
pentax k3 problem battery Luigino Pentax K-3 & K-3 II 7 12-04-2013 12:43 PM
All times are GMT -7. The time now is 08:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
