Originally posted by fwcetus Thanks for your input, Tas.
1. I am confused (sorry) by "metering in landscape/portait orientation differs" -- do you mean that metering differs between landscape orientation and portrait orientation, and if so how?
2. You mentioned "when focusing wide aperture lenses manually" -- what effect(s), if any, do you see when using slower lenses -- how does focusing seem with slower lenses, and/or is there any screen darkening because of the S screen, and/or...?
Thanks for clarifying.
Hi, sorry for the late reply.
1. Normally I shoot in manual and Av. When in Av there have been occasions where the change of camera orientation meant the need for exposure compensation. It was usually a case of a correctly exposed image in landscape to underexposure when going to portrait orientation. Of note is my choice of screen, the S type with grid and AF frame, which as indicated will cause issues with exposure. It's a non-issue in manual mode and to be honest I don't think it's anything more than annoying; though my next S type will have the grid pattern still, I will drop the AF frame.
2. I don't really notice the difference with slower lenses or when stopping down. Maybe because it's been so long since I used the standard screen, so whether in comparison to the standard screen it is harder or not I don't know. I don't notice it to be honest and get more out of having the S screen than not. My hit rate with wide apertures was too low with the standard screen and when I buy my next camera I will be looking to using an S type again.
Hopefully that clarifies my responses better.
Tas
